Old 11-16-2009, 09:02 AM
J.D.Oldham's Avatar
J.D.Oldham J.D.Oldham is offline
Default International engine spec.
I'm looking for small V internal parts interchange. I guess I just don't know where or how to search. I tried the B.P., B.B. and Google. I'm looking for crankshaft size, stroke, bore size and rod length.
Thanks
78 Scout II 4" lift 36" TSL, 304, locked & locked
Hunter's 1966 Travelette, 304 4 speed track-lock
76 Scout II 32" 400 MOPAR, broke
2- 74's and 76 Terra
18 pass. school bus for storage(soon to be a woods cabin)
Old 11-16-2009, 09:33 AM
Tim Potter's Avatar
Tim Potter Tim Potter is offline
Default Re: International engine spec.
all of that is in the FSM
1977 Terra 304, T-19wr, D20
1974 SII, 345, T-19W, D300, SOA, Deaver springs, D44 Alloy USA chromoly shafts, ARB front, high steer; D60, 35 spline semi-float shafts, ARB, disk rear, hydro boost, CV shafts, Bilstein 5125 shocks.
Old 11-16-2009, 09:56 AM
Dan Phariss's Avatar
Dan Phariss Dan Phariss is offline
Thanks
The 345/392 use the same crank and the 266-304 use the same shorter stroke crank, all 4 engines use the same bearings and seals. I think the smaller 2 use the same shorter, lighter rod. But the early 392 uses a unique rod but about 1975-76(?) they strengthened the 345 rod and used them in both the two larger engines.
Cams and lifters are the same for all, rocker shafts are the same. Pushrods are the same for 266/304 but the 345/392 are longer. The heads are usually displacement specific but the *early* 392 will accept 345 heads increasing compression but the valves are smaller. The later improved cooling 392 block and heads are different and *will not* accept 345 heads
There is no way to bore a 345 safely to 392, the castings are all displacement specific so the 345 block does not have sufficient cyl wall for the overbore. Or so I have read. Nor can you make a 304 into a 345 by changing the crank, the 345/392 has a taller block and it just will not work even though the 304 and 345 use the same piston.
I have heard that the 266 will bore to 304 but I do not *know* this for sure.
Dan
Dan Phariss
66 1200A 4x4
74 200 4x4
75 200 4x4
"The meek shall inherit the earth, generally in small plots about 3X6X6." Robert Heinlein
Old 11-16-2009, 11:22 AM
Tim Potter's Avatar
Dan
This is true. The 392 cylinders, 4 1/8" bores, are siameesed for increased wall thickness between cylinders while there is a 3/8" +- gap between the cylinders, 3 7/8" bores, in a 345 block. The siameese cylinders are one of the reasons the 392 had cooling issues in large trucks which led to the IC version which flows the water into the block instead of the head
Old 11-16-2009, 11:30 AM
db1115's Avatar
db1115 db1115 is offline
Dan
Can anyone verify this? Standard 304 pistons might be esier to find than oversized 266s.
Davis
Old 11-16-2009, 01:48 PM
J.D.Oldham's Avatar
What is FSM? I want crankshaft stroke, rod & main size & rod length.
Old 11-16-2009, 05:00 PM
Tim Potter's Avatar
in the back of the Factory Service Manual in the section discussing engines there is a specifications section (2 pages) listing all of the engine specs for I4's and SV's 152 - 345. 392's are not covered in the Scout manuals because those motors were not available in Scouts
Sorry Man, I thought you had one
Old 11-16-2009, 05:31 PM
J.D.Oldham's Avatar
Nope! No service manual, maybe Santa will bring me one for CHRISTmas.
I was just doing a little thinking (see the smoke coming out my ears), maybe a 304 crank in a 392 block, 392 or Chevy rods, and custom pistons. Make a little winder with a short stoke and big bore. Just dreaming!
Old 11-16-2009, 06:43 PM
The factory service "shop" manual is available from binderboooks.com
Peruse the "Skunkwerks" forum for this kind of information. It has all been hashed out before.
To the best of my knowledge, the 266 cannot be boired to 304.
Old 11-16-2009, 07:04 PM
Tim Potter's Avatar
I hope he does.
stroking a 304 is not a dream and you dont need the 392 block to do it. welded 304 crank, longer rods and custom pistons makes a very nice 383 with room to spare. a 392 can be taken all the way to 440-450 without a problem. plenty of block clearance, the only questionable area would be whether the big ends of the rods will pass the cam lobes since they get to be in pretty close proximety to each other.
I can tell you who to talk to about this if you'd like, he already has the numbers worked out, and where to buy the rods and pistons. I'm kinda looking to build a 427 out of a 392 when money is available and that's just a stroke, still using 4 1/8 pistons; go to 4 1/4" and ya got a 440. I do like the idea of keeping the motor a little more square though or going wider like you are talking about. There's so much meat in these cranks you can do just about anything in terms of welding and offset grinding and, still have a strong sombich slingin' the slugs. It's only money.
1975 , 345 , 392 , bearings , binder , body , build , cam , christmas , compression , cooling , crank , custom , engine , external , international , parts , piston , rebuild , scout , transmission , truck , vendors , water , wiring
Cost comparrison...Swap in power or build up an IH engine? Mike Moore General IH Tech 328 06-12-2011 07:51 PM
52 international pick up engine swap rons rodz General IH Tech 4 11-27-2007 04:02 PM
this is kinda wreid fordnissanpower Diesel Tech 7 11-19-2005 04:34 PM
When to give up on an engine - long nrwhite General IH Tech 7 10-05-2004 07:30 PM
international stationary engine snowjob Triple Diamond Trucks 4 04-28-2004 11:48 AM
