Old 09-27-2009, 12:52 AM
Erik VanRenselaar's Avatar
Erik VanRenselaar Erik VanRenselaar is offline
Default Re: Where are all the pizza cutters?
Originally Posted by ScoutFam View Post
...I was always told that for every 3 or 4 inches you raise the truck you need 1 inch in width to compensate or the rig becomes to tippy...
Who always told you that?
'75 & '76 Scout IIs
Amateur radio operator, General Class - K6IHC
Work Smart, Not Hard...
Old 09-28-2009, 12:43 PM
cheyladd cheyladd is offline
I'll bite with my new to me truck. These are 8x19.5's. Measure 35 inches tall and maybe 8 wide at the most.
1966 IH Travelette 4X4 3/4 ton
1972 Chev SWB Cheyenne Super 4X4
Old 09-28-2009, 04:09 PM
Jesse Ray's Avatar
Jesse Ray Jesse Ray is offline
More pic's More pic's
1980 Scout II, 304, full width SOA, 8 lug d44 ff14bolt w/disc, stock'ish springs 35's - "first build"
Originally Posted by 641500
. I strenuously object to funding any large scale humanity free zone
Old 09-28-2009, 05:11 PM
Heres 33 10.50 15 with 4 inch triange with extended rear shackle
Old 09-29-2009, 12:46 PM
jmaroon's Avatar
jmaroon jmaroon is offline
Send a message via Yahoo to jmaroon
refresh my memory.. aren't bias ply tires bad for getting flat spots in em after sitting a couple days? do they wear any better or worse?? what are pro's and con's between radial and bias ply??
You only need two tools in life: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
76 scout II 345, 4" lift T-19 d20....... and my hula girl on the dash..
Old 09-29-2009, 02:11 PM
Jesse Ray's Avatar
Bias tires have flat spots and have very limited applications in my mind.
However, they are inexpensive (generally speaking).
Radials seem to run cooler, ride better, etc. Quite frankly a better choice for most applications. In the ATV business, radials are the best choice.
i suppose it is kind of like - I would rather drive my truck, or wife's car if I were traveling some distance because of practicality. However, I still like my scout for everything else.
Old 09-30-2009, 04:08 PM
ridgway ridgway is offline
I ran 34x10.50 Ltb's and they work awsome not to mention the price. If you want an awsome 34" and don't want the rain, mud, snow flying all over the truck and side windows I would recommend the skinnier tires. Plus I love the look and the vintage wheels.
Old 09-30-2009, 07:03 PM
robrob's Avatar
robrob robrob is offline
I like the cutters on the 800's but have not seen them on the SII enough to have an opinion. If I had that sweet 80/800 body style I think I would run cutters.
'79 Scout II 345 Auto Dana 44
Old 09-30-2009, 07:06 PM
Jesse Ray's Avatar
I am in the same boat. I want to see, hear some responses of the 34LTB's and the like.
Things such as clearance, rubbing issues, and of course, even if mine has a scooby stripe (rainbow) on the side of it, I do care about the looks.
ha ha
Old 10-01-2009, 03:15 PM
The 34 Ltb's I have work like a charm. They weight alot less that you would think and alot less than the Boggers. I have 8" of lift and have no problems rubbing with 8" wide wheels.
4x4 , 800 , axle , axles , body , build , cooler , efi , ground , lift , pictures , power , pto , rear , safety , scout , screws , soa , switch , tires , top , trail rig , truck , wheels , winch
Plasma cutters NCScoutGuy General IH Tech 19 02-28-2009 08:05 PM
tire advice mdmcs1 General IH Tech 20 01-20-2004 01:17 PM
Pizza Friday, March 14th RD Durham Rocky Mountain Binders 0 03-11-2003 07:03 AM
