Old 09-10-2009, 08:03 PM
ADAM NANCE's Avatar
ADAM NANCE ADAM NANCE is offline
SEBA Moderator
Default Travelall fuel tank replacement
Has anyone replaced a tank with one from another vehicle? My tank is past gone and i need to replace it. Its a 73 travelall 1110 4x4 392. Any help would be appreciated. Thanks Adam
1976 TERRA
1973 TRAVELALL 1110 4X4 392 (DADS)
1979 SCOUT II 345 T19
1976 SCOUT II PARTS RIG
Old 09-10-2009, 08:04 PM
ADAM NANCE's Avatar
SEBA Moderator
Default Re: Travelall fuel tank replacement
Forgot Its the one under the cab that fills through the fender.
1976 TERRA
Old 09-10-2009, 09:33 PM
LeeC
Guest
Posts: n/a
I'm interested in this too. Any replacement suggestions are greatly appreciated.
Old 09-11-2009, 02:32 AM
pri's Avatar
pri pri is offline
Yeah, I'm getting into this too... Wanna do a replacement on the 1000B, between the frame rails at the rear. Chebby van tank is too wide and too deep.
Paul Wargenstahm
Certified Electrician
Computer & Electronics Engineer
1967 IH 1000B with GM 6.2D, TH700R4, running WVO and BioDiesel.
1964 IH C1200 4x4. The new one...
1976 Scout II
Build-up pics at: Paul's IH Pages
Old 09-11-2009, 09:29 AM
Unless there is a a large hole or the bottom is a sieve, tanks can be rejuvenated with a tank sealer kit from POR or Eastwood or others. If you have a small airport near you, they have really good stuff to coat/seal tanks.
Remove the tank. Clean it first with phosphoric or muriatic acid: put a handfull of nuts and bolts in it and with a buddy, rattle it around until your arms fall off. Rinse, drain and dry then use the sealer according to directions. Good for the life of the truck.
To the best of my knowledge, nobody makes replacement tanks. Should you find a good used one, clean it and seal it before you install it for trouble free function.
Old 09-11-2009, 09:30 AM
ClemsonScout's Avatar
ClemsonScout ClemsonScout is offline
I've heard of guys using a Chevy pickup tank. I'll see if I can find out the details.
Robby
'76 Scout II - 345, T19, 2.5" Rancho, 32" BFG
'73 1010 Travelall - 392, 3.31's
'80 Scout II - 345, 2.72's
http://www.southeastbinders.com
Old 09-11-2009, 05:33 PM
ADAM NANCE's Avatar
SEBA Moderator
Im checking out a tank off a 86 chevy p/u this weekend. By the specs it may just fit with a little modification. I'll keep yall posted.
1976 TERRA
Old 09-11-2009, 08:29 PM
nekbinders's Avatar
nekbinders nekbinders is offline
I have tanks!! They are steam cleaned, lined, and painted, like new. $125 plus S&H.
Old 09-11-2009, 08:44 PM
ADAM NANCE's Avatar
SEBA Moderator
nekbinders pm sent!
1976 TERRA
Old 09-20-2009, 08:52 PM
Cory Smith's Avatar
Cory Smith Cory Smith is offline
I'm planning on installing a Scout II tank in my '63 t/a this week. I will have to remove the furthest back crossmember and relocate it. No big deal, I will beef it back up with a reciever hitch. The tank will fit fine and my intention is to use a stainless steel boat fuel filler on the quarter panel. I will post up my progress in the Travelall Cruiser thread in skunkwerks.
Just Internationals
'73 Scout II, LS 5.3
100 , 1000 , 110 , 4x4 , bar , binder , body , build , cap , door , frame , front , gauges , hanger , mount , panel , pickup , rear , replacement , scout , scout ii , travelall , truck
fuel tank size comparison? mudmovers General IH Tech 4 08-09-2007 11:48 PM
In tank fuel pump question tom caudle Southeast Binders Association 3 02-13-2007 09:43 PM
In tank fuel pump? Stan-M General IH Tech 3 07-03-2005 11:15 AM
Scout 800A no gas feeding passenger tank badgerwest General IH Tech 11 06-17-2005 11:03 PM
Fuel Tank Troubles C.Hamm General IH Tech 1 03-24-2004 10:31 AM
