Old 08-06-2009, 04:22 PM
wavesailr wavesailr is offline
Default 1978 Scout II 392 V8 Engine Problems...
I've got a 1978 Scout II with a 392 V8 engine that's giving me problems only after it gets to operating temperature.
The engine backfires, misfires, stumbles badly, and has nearly no power after the engine gets to operating temperature. Before it's warmed up it runs perfectly and has lots of power.
I've replaced the mechanical fuel pump and that didn't help. I then bypassed the mechanical fuel pump and used an electric fuel pump. That didn't help either. The fuel pressure is about 3 PSI when the engine is running no matter if the engine is cold or hot at full throttle, or idle.
The timing is good at 3 degrees btoc using the #8.
The carb (Edelbrock Performer 600 CFM, electric choke) was replaced before I owned the Scout, but it looks fine.
The distributor and coil were replaced and didn't help.
All of the fuel lines are routed away from hot-spots.
Please help!!
Old 08-06-2009, 04:31 PM
Default Re: 1978 Scout II 392 V8 Engine Problems...
Vacuum leak. Use your propane torch [don't light it!]. With the engine running, pass it over the carb opening: the engine will either speed up or lug down from the extra fuel intake. Use that as your indicator. Now pass the torch around the base of the carb and the various fittings on the carb including the shaft pivots. Watch for the engine response. When it responds, there's your leak.
Also check any of the vacuum fittings on the intake manifold especailly thee brake booster. Do the whole test in 5 minutes.
Old 08-06-2009, 04:41 PM
Thanks for the quick response. I"ll try it tonight.
The bogging and backfiring is only under load/acceleration. The engine idles perfectly both when it's cold and at operating temp...
Old 08-06-2009, 05:31 PM
scoutboy74's Avatar
What Doc suggested has plenty of merit and should be followed. From your description, this could also be an air/fuel ratio problem. When cold, your engine craves more fuel than air, but this changes as the engine approaches operating temperature. Verify that your choke plate operates smoothly and that it opens fully as the engine warms up.
Trever Whetzel
Fat White Boys
Binder Recovery
& Rehabilitation
SHOP NORTH
Old 08-06-2009, 05:59 PM
Russ McLean's Avatar
Russ McLean Russ McLean is offline
>> The carb (Edelbrock Performer 600 CFM, electric choke)...
Verify that the electric choke has 12 Volts and is properly grounded. Measure this on a warm, running engine.
Still plays with Trucks
1975 Scout II - SV392
1986 F150 short bed, Cummins 4BT, 5 speed trans, 1952 Bell Telephone Co service bed, 2014 Diesel Confab - 22 states in 15 days
Twinkie Truck - 1986 Grumman bread van - now another storage building
Historic Vintage Truck Association
Old 08-06-2009, 06:35 PM
Thanks,
Electric choke works fine. Choke plate opens smooth and is 100% open after running for a few minutes and stays open while hot and running.
Old 08-06-2009, 08:24 PM
1975IH200's Avatar
1975IH200 1975IH200 is offline
Send a message via Skype™ to 1975IH200
Be sure the electric choke is NOT powered from the ignition system.
The has caused several people here problems, caused by the PO Monster.
1975 "306" AWD
Western North Carolina
SEBA / Southern Scouts
Old 08-06-2009, 09:40 PM
70binderPA's Avatar
70binderPA 70binderPA is offline
Send a message via AIM to 70binderPA Send a message via MSN to 70binderPA Send a message via Yahoo to 70binderPA
i had a blown head gasket do the same thing. cept it was blown between 6 of the cyl's to each other
'70 1100D, 392/727/202, d60/d44
www.homegrownboost.com/forum
Old 08-09-2009, 04:48 PM
Okay,
I just sorted it out.
There was a missing ballast resistor. 12v was going directly into the coil and causing the coil to get REALLY hot.
So, I bought a resistor and installed it. There's now about 6v going to the coil and distributor.
That fixed the problem perfectly. Now there's tonnes of power when the engine is cold AND hot!!
I tried the propane torch and it didn't change the rpm at all, even when I shot the propane directly into the carb... It sounded like a good idea though.
Thanks for all your help guys!!
Rob.
Old 08-09-2009, 08:47 PM
70binderPA's Avatar
Originally Posted by wavesailr View Post
Okay,
Rob.
if you're only getting 6v something is wrong.
100 , 3.4 , brake , carb , coil , distributor , engine , fuel system , head gasket , idle , ignition , key , lock , number , pickup , power , scout , scout ii , throttle , timing
ENGINE SWAP 258 to 392 1973IHC1010 General IH Tech 12 06-30-2004 03:54 PM
