Old 06-30-2009, 06:17 PM
ajdata ajdata is offline
Default Transmission Mount
Recently installed the transmission mount on my Scout II w/ 727 tranny. The old one was shot and only finger tight.
Installed the new one and now my car shakes like crazy when I give it gas while parked. Perhaps the mount is supposed to float and not be too tight?
Forgot to mention this is the mount sold by IHONLYNorth
http://www.shopih.com/SSP-02-T-18-p-T6.html
1977 Scout II XLC w/ 345 + 727 trans
Old 06-30-2009, 06:27 PM
Default Re: Transmission Mount
No, the mount is not supposed to 'float' You can use a hard poly mount even.
Check your engine mounts. Firming up the trans may expose a bad one [or two] on the engine.
Old 06-30-2009, 06:28 PM
That's what I was afraid of. Any reason not to drive it around town on short trips?
Old 06-30-2009, 06:44 PM
john breeze john breeze is offline
Car?????
Old 06-30-2009, 06:54 PM
i agree with Doc. in the past i have always replace all of the mounts at once that way you know they are all good and ready. sorry had to say something about the car thing
Old 06-30-2009, 09:41 PM
yay...that is a huge party foul on my part.
Old 07-01-2009, 08:29 AM
D. Webb's Avatar
D. Webb D. Webb is offline
I'm gonna jump on the motor mount band wagon aswell. I experienced the same problem after installing my new RPT trans mount. I took a look at the motor mounts and it was obvious that one of them was bad. SO I replaced them with the RPT rebuildable mounts and viola! no mo shakin. Good Luck.
1978 Scout II, 345, AT, SOA with 2.5" Softride, Hysteer, RS, 35" Dick Cepek MC's
Old 07-01-2009, 08:54 AM
D. Webb,
Thanks for the info. I have the RPT motor mounts as well. What is the procedure to replace them? It looks to be difficult and like it will need to life the engine 3 to 4 inches to get the new mounts in. Any suggestions would be greatly appreciated.
Old 07-01-2009, 07:43 PM
ClemsonScout's Avatar
ClemsonScout ClemsonScout is offline
I've used both the engine and tranny RPT mounts. I could slightly tell the difference with the engine mounts, but when I replaced the tranny it was a big difference. At higher speeds you would feel much more vibration. If I would do it again I'd stick with the standard tranny mount and do RPT just for the engine.
Robby
'76 Scout II - 345, T19, 2.5" Rancho, 32" BFG
'73 1010 Travelall - 392, 3.31's
'80 Scout II - 345, 2.72's
http://www.southeastbinders.com
Old 07-01-2009, 07:56 PM
Mt Hood Carl Mt Hood Carl is offline
Originally Posted by ClemsonScout View Post
If I would do it again I'd stick with the standard tranny mount ....
Are standard trans mounts available anymore? Where?
bar , case , click , difference , engine , ground , lift , mount , mounts , oil , parts , plug , question , rubber , scout , scout ii , steering , strap , t-18 , tranny , transmission , transmission mount , truck , vibration
