#411
Later, TR
Stephen Watts 1968 800 266, 4 speed 1968 1200C Travelette 345, 4 speed barnes4WD.com |
#412
I started by cleaning the underside of the hood and applying a simple weatherstripping around the perimeter of the hood. It might not make any difference at all, but there's a groove there so why not try? The existing silver stuff is the initial round of sound deadening that GRC applied. It was NOT easy to have that professional of an install, I can tell you that from having to install similar stuff on the firewall.
![]() Then all careful-like, trace out the shapes of the hood inserts. Take care to trace correctly "L" and "R" side shapes... Yes, they're the same on both sides, but the sound deadener is directional. ![]() The sound-absorbant material, all cut out: ![]() And being smart about it, had some reasonably sized pieces for applying elsewhere: ![]() Peel and stick. It's not as sharp or tidy as GRC's install of the initial stuff, but I wasn't too worried. The adhesive is pretty unforgiving too, so be purposeful: ![]() I didn't take any pics of the firewall, but use your imagination. it looks like a hodge-podge of the same material that you see in the finished hood above, and there's a similar initial layer underneath.
Don Raleigh, NC |
#413
Did a bit more for sound levels, can't think of much else to do... Got interior idle down to 74dBA and normal driving around 84dBA. Can find 91dBA if I try.
Previous tank of fuel was purposely spent very conservative with the throttle and driving manner, doing everything reasonable in traffic and with respect to other drivers to make it stretch... Probably 85% in town driving at 45mph or less, lots of stop and go. Got 28.3mpg! Then filled up, took the top off to enjoy the weather, and commenced to thrashing it. Same breakdown but... High rev take-offs from red lights, passing people on hills, aggressive merging, etc. Right at 23mpg! I haven't been up on the highway much, and since the rig ws geared for that I'd think the results would be favorable. Just gotta talk honey into an all-day highway run in blazing sun and 99deg heat.
Don Raleigh, NC |
#414
How's the cabin noise with no top? Driving it like a high school kid and your still double the mileage of most scouts.
Randy and Kelly groenhof |
#415
Free field is a bit quieter, but without the top you really hear the reflected noise from adjacent cars, fences, etc. Probably about the same in the end.
Don Raleigh, NC |
#416
28.3!?! That can't be too far off from the Mini. That's awesome. I bet you taste the diesel after a day riding around topless. Does it feel alot lighter minus that 300ish pound top?
Jason Honeycutt 1978 IH Scout II EFI 1978 IH Terra trail rig G R C built S E B A www.youtube.com/jhnyct |
#417
Nah, I actually don't smell too much. It runs pretty clean and only puffs black smoke when I really goose the throttle. Only time I've really noticed it was bringing home a long box from the store, with the top on but liftgate open. The exhaust was drawn back in and escaped the cab via the open driver's window (and therefore right across my nose).
![]() It does seem to be a bit more spirited with the top off, but that could be that I'm getting re-acclimated to driving a Scout on a daily basis and driving with more zeal. And it is kinda fun to blast past people with the stereo up on my drive home! ![]() The Mini (Cooper S, not modified) was sold about two months ago, but you're right--the mileage isn't too far off. When driving that wheels off the Mini and with the bike rack on I typically got 27mpg. With the rack off and taking it easy I could get more like 32mpg.
Don Raleigh, NC |
#418
-Jamie Illuminati Assassination Bureau... Sniper division Project Petey - 1980 Scout II, 345, T19 wide, D300 daily driver A line of rusty support vehicles |
#419
On the way home from work yesterday, cleared 5000 miles since build completion! The top is still off, but I think it'll have to go on soon. I don't care about cold, but it will rain eventually as the winter approaches.
It's had a few minor glitches, but nothing that I can't deal with or get fixed eventually. With a project of this scope, bugs were expected. In retrospect, I might have done a few things different on the design but I don't regret doing it. It's a great daily driver, with smooth acceleration, strong brakes, and two-finger steering. Fuel stops sting (33gal tank @ $4+/gal), but I'm only filling up once a month or so. Anyway, good times. Just wanted to report the milestone.
Don Raleigh, NC |
#420
Don,
Thanks for keeping us informed
'80 Scout SD33T 260,000 Mi - My youngest son, Me - '93 Dodge Cummins 4X4 334,000 Mi., '68 El Camino W/early 1970's 6-33 500,000 Mi - My oldest son. '90 Dodge D250 w/a '96 Cummins 215,000 Mi. 1960 Farmall Cub, 1948 Farmall MD. 1948 KB3.Pics! |
| 1980 , axle , binder , build , bushing , case , column , cummins , custom , diesel , engine , fluid , frame , part , power , power steering , project , radiator , scout , sd33 , start , starter , steering , top , truck |
