I've finally started some real action yesterday. I picked up a 4bt about 2 months ago and started putting things in motion. The 4bt was sourced for my C-series Travelette project but was shutdown to focus on the restoration of my A-120 over the next few years; the 4bt shifted over to this, and I couldn't be happier. Since my Traveler is in pretty good shape it won't be doing any significant wheeling. Since it's set up for automatic, I'll be going for a 4x4 46rh/47rh when I can find one for a reasonable price. The passenger side drop of the front axle will make for tricky exhaust routing, but I think it'll work out. If not, I'll fight that battle later. One of my objectives is to have nothing outwardly indicating that this is any different than any other Scout-- no cutting the hood, no stacks, nothing retarded... I'm excited that it's going to be a diesel, but I'm more proud to drive a Scout. The 4bt itself will be painted IH red. The operational objective is to have the best of all worlds: torque, towing capacity, mpg/range, reasonable highway comfort, etc. Most of its driving will be kicking around town, going out to the beach, and weekend camping trips to the mountains. Just a great all-around Scout. So basically it's going to be what a Scout already is but with better fuel economy. The 345/727/D20 setup got pulled yesterday, and the engine compartment will be cleaned and prepped in the coming weeks. My 4bt is supposed to already be in good shape, but there's a recommended diesel guy nearby who will be going through the motor to be sure. Right now the task is to thoroughly clean the engine compartment after 33 yrs of the IH factory oil leaks, then establish as much sound deadening/isolation as possible for the passengers. Where I am, and where I want to go: The truck has D44s front/rear with 3.54 gears, and the tires are 33-10.50 BFGs. That seems to put the 4bt in a great RPM range for all ranges of driving. Lift is a 4" Triangle with slightly longer-than-stock shackles and Procomp 9k shocks. I have the 33-gal fuel tank and a new Griffin aluminum radiator w/ integrated trans cooler. The Griffin is the style needed for a SV, so passenger side upper inlet, driver side lower outlet. I think the 4bt can be adapted to fit that, and I'm pretty confident the Griffin has enough cooling capacity for the 4bt. I will be going with an electric fan. The body bushings on the truck are the factory ones and have squashed over the years; I have a new set that will be installed in this effort. If the 4bt will still not fit, I'll only add enough body lift to squeeze it in, but I hope not to. The Traveler's A/C works great and we were able to move everything out of the way for engine removal without cracking the refrigerant; everything will be mounted up to the 4bt later. Question: The A/C heat exchanger in front of the radiator takes up a fair amount of room and I'm concerned about the front surface area recommended for the intercooler. Ted has a Perkins diesel in his truck and the intercooler is maybe 2 sqft? I realize I'll be able to find different shapes/sizes for the intercooler, but how small (or big) would you guys recommend? I'd like to find one that wide but not tall, that can fit below the A/C HX in front of the Griffin. I share my garage with a drag race guy, and he's going to help me with the intercooler, bracket fab, and other bits. Master Groenhof will be leading the charge on placing motor mounts and cross members when the time comes. While it's gutted, I'm going to clean up the steering with a lower Borgensen joint (I did the upper already) and do the bright lights kit. After the 4bt is up and running, the Traveler will get its axles cleaned up/gone through and get discs all around. At some point I'll cut down the liftgate and install a regular Scout tailgate. I also have a factory Warn bumper and rebuilt Warn 8274 that will be installed. Yeah, it's a bit poser but it looks cool and the winch has come in handy on Robby's Scout on more than one non-trail occasion lately. Feel free to offer critique and recommendations, but don't knock the choice for going with an automatic. That decision has been made. I'm open to suggestions and ideas, even if they're little ones. I'm trying to read other build threads to catch lessons learned but I still have a lot to learn.
Don Raleigh, NC Last edited by TheDon; 06-09-2009 at 05:07 AM. Reason: words |
Glad to see you are getting started on it. I recommend replacing the rear main seal, installing a 3200 RPM governor spring, and taking care of the Killer Dowel Pin while the engine is out. The last 4bt I did I used a stock re-cored Scout II radiator with a crossover pipe on the lower radiator hose and it cools fine. These engines run very cool.
I too like having more of a stealth look without the stacks, etc. However you will get alot of people pull up beside you at intersections and roll down the windows when they hear it running. I finally put a couple cummins emblems on mine to reduce the questions I get in parking lots. There is a another guy here local with a 4bt/700R4 setup in a Scout II. He kept the passenger side front axle and ran the exhaust outside the frame and out right in front of the rear tire. He complained of the exhaust resonating inside the Scout. Try and exit the exhaust out the back if possible. Have fun.
Sounds awesome Don, I think the new powerplant will work a lot better for you in the Scout. My Duramax was an auto and pulled like a champ, I think you'll be happy with the auto. You probally won't be pulling enough with it to even consider the obsticles to convert it to standard. Good Luck.
67 800 Limited GRC Edition, 266/T-19W/D300 79 Terra Rallye, mostly stock driver 61 Travelette, KOH Chase inspired build...........one day! 1250 Cub Quietline |
Thanks for the support Cory, I've read and re-read your builds several times. I only wish you were closer to me so I could bribe you to help! You get more done in a long weekend that I'll get done in a good month.
In reference to the 700r4 in the Scout you mention.... I don't know that truck or owner, but I read mixed reviews about the 700r4. From what I can tell, the 46rh was behind the 6bt, so it should be a direct bolt-up, and they are (supposedly) a little better behind a diesel. I don't know, 700r4's seem to be all over the place. I'll have to weigh the availability versus what I've read if a 46rh doesn't show up soon.
Don Raleigh, NC |
I think the dodge auto will hold up better. It will be more expensive of course. The dodge flywheel housing, stater and flexplate will be easy to find. An automatic would be fun to have in one of those. The engine will stay in it's powerband a bit better and you wont lose your boost when you shift gears.
I keep saying 46rh, but a 47rh would be great too if any one has either one laying around....
Don Raleigh, NC |
Great project!
Here's another guy who's gone there before: http://wheelindixie.com/forums/showthread.php?t=2792
-Jamie Illuminati Assassination Bureau... Sniper division Project Petey - 1980 Scout II, 345, T19 wide, D300 daily driver A line of rusty support vehicles |
Thanks Jamie! That guy's not too far away either, might drop him a line. He's done a few things that I'm not anticipating (hydroboost, routing the exhaust over the bellhousing to the driver's side, etc) but it's good to see other ideas.
Ironically, like that guy, I've been planning to paint the 4bt itself IH red and also with chrome/silver valve covers. I dig it.
Don Raleigh, NC |
I haven't met Mike in person, but they say he's a good guy, I'm sure he'd be glad to tell you any issues he ran into. He's a diesel nut, so he should have plenty of info on what your options are. It's gonna be a cool build when you're done.
![]() eta: Check out the last post in Jeff's thread on engine cleaning.
-Jamie Illuminati Assassination Bureau... Sniper division Project Petey - 1980 Scout II, 345, T19 wide, D300 daily driver A line of rusty support vehicles Last edited by Red_SC; 06-08-2009 at 07:13 PM. |
I ordered up some sound-deadening paint (like Lizard Skin but 1/3 the price) today, but I don't imagine I'll be doing that until next weekend. There's 33 years of grease on the front axle and forward frame section that will keep me busy for a while on Saturday with degreaser and a pressure washer. Like Jeff, I'll conveniently forget my camera.... If the paint gets here in time for the weekend, maybe I'll do the first coat on Sunday. I'm going to do a couple of coats of that stuff (we'll see if it's any good) to mitigate the rattle and clankity-clankity of the 4bt. Later I'll pull the front seats and put a coat of that stuff on the inside too, but the priority is getting it up and running again.
The diesel mechanic should be coming by to get the 4bt this week, doing his inspection, and at least doing what Cory recommends above. If he comes up with anything else, we'll tackle that later.
Don Raleigh, NC |
| 1980 , axle , binder , build , bushing , case , column , cummins , custom , diesel , engine , fluid , frame , part , power , power steering , project , radiator , scout , sd33 , start , starter , steering , top , truck |
