the Scout that I recently purchased had a terrible wiring job to the rear and the tail lights were not even installed....the previous electrician had ran house wire from the front to the rear and used wire nuts to connect everything
in the interest of saving money on a project that may never see the road, i have decided to try rewire the entire rear harness from scratch i'm trying to follow this wiring diagragm http://www.binderblues.com/main/tech_imgs/rearharn.gif i'm ignoring the interior dome lights and all i need to wire are rear side marker lights, tail lights, brake lights, reverse light, and license plate light, 5 circuits from my count......i didnt forget about the fuel sending unit either coming out of the front firewall is a cluster of 7 wires, 5 black and 2 green which i presume to be grounds (this might be a good time to mention i am an amateur electrician as well as amateur mechanic) ![]() i've got plenty of 16 gauge wire ready and i've practiced my soldering skills.....i've also got enough wire protector sleeve and heat shrink tubing to wire a whole fleet of Scouts i guess i just need a place to start.....advice / tips / help? should i start with the drivers side marker light and work my way around and up to the front? start at the front and work my way back? i'm kinda confused how i'm going to splice everything together without connectors??? for some stupid reason i also thought i could ground everything directly to the body but then what are the two grounds included in the cluster of wires (if in fact they are grounds in the first place) i'll finish by saying that i have a degree in mechanical engineering so i'm at least confident that i can accomplish about anything if i try so i don't imagine wiring some tail lights would be too hard to figure out....i just need a kick in the right direction
When you rewire, what type of wire are you going to use....I saw this tinned copper wire at the store the other day and regular copper wire....
Which one is better, and what are the benefits? Good luck on the rewire, I am about to do the same, and I am just taking my time researching, and researching more. |
The wiring in a 1961 Scout is very different than the wiring in a 1980 Scout. We will need a couple of clues. Get a test light or voltmeter and verify what voltage is on each wire. Temp, oil pressure and fuel level (assuming that the Constant Voltage Regulator (CVR) is working will have pulsing 12 volts that averages to about 5 volts. Use a resistor to ground (any where from 10 to 40 ohms) and see which gauge moves. Ignition comes on when the key is in the "run" position. Accessory comes on when the key is in the "accessory" position. Same tests for the light wires.
Still plays with Trucks 1975 Scout II 1971 1210 Travelette Twinkie Truck - 1986 Grumman bread van with Cummins 4BT - needs tires, now another storage building 1957 Studebaker stationwagon (waiting its turn) Sonora Desert Scouts Historic Vintage Truck Association |
You've gotta love to hate the ALL GREEN WIRING these trucks have
. Makes tracking the other end down next to impossible at times. Proper test equipment is a most. I'm going the Wiring Kit route on my project. Something like Painless with all the wires labeled. Best of luck with your project.
The green wires are the ones for the dome light. The marker, running, and license plate lights are all the same circuit. Then you have the backup lights, L turn/brake, R turn/brake, and the fuel sender.
If you have the stubs of the OE wire connected to the bulkhead connector the cir numbers are as follows. #36 fuel level, #56 L turn/brake, #57 R turn/brake #68 tail #71 back up. The #'s are printed on the wire near the connector in white. IH does use color coding green 18ga green, black 16ga, white 14ga, red 12ga, blue 10ga. Jack, the tinned copper wire is commonly used in marine applications, it is more corrosion resistant than standard copper wire.
73 SII cab top 345 t18 d20 d30 d44 3.73L ps 72 SII trvl top 345 t18 d20 d30 d44 3.73L ps pb 72 T-all 1010 custom 392 MS-II FI 727 d44 3.73 ps pb ac 73 T-ette 1210 304 727 np205 d44 d60 4.09/4.10 ps pb 73 1510 345 t19 RA25 6.17 |
Thanks Eric, I found some on sale really cheap 16 gauge, and wanted to make sure I could use that just as well.
i really need an automotive wiring for dummies book
For your rear harness:
#16 wire Right turn / Left turn / tail including clearance and license plate / reverse #12 wire Blue for the trailer connector for electric trailer brakes #14 Red for charging a trailer battery. Ground all lights to the body. Use a ground strap from body to frame and from frame to battery as well as engine block to battery. For your front harness: #16 wire Right turn / Left turn / clearance / If you use relays for your headlights and driving/fog lights, you can run # 16 wire to the relays. Use #12 from battery to relay to lights. If you don't use relays, run #12 wire from the switches to both.
i dicked around and didn't get to tear into this too much
i inspected the connection at the firewall and didnt want to tear into the dash this late in the evening one of my 5 black wires goes somewhere down to where the transmission used to be so i would guess that is the backup lights with a reverse sensor on the trans? the other wires are all on a 6 pin connector at the firewall........is the location on the connector a clue as to what they are or not? |
Get the wiring diagram for your truck - it is posted on here somewhere. Standard advice is to buy the shop manual from any light line dealer or binderbooks.com.
| 1980 , alternator , amp gauge , body , brake , cvr , engine , frame , front , headlights , ignition , key , lights , oil , parts , project , scout , scout 2 , start , starter , strap , trailer , truck , voltage regulator , wiring |
