#31
1967 1200A 4x4, 304, T36 5-speed, Dana 44 front, RA10 rear, 7' bed, Stans & Flows, 11.00-16 Michelin XZL tires 1973 1310- Ex PG&E truck, 11,000 GVW, 392 w/Schneider cam, Stans, Flowmasters, 727 w/ GV OD, RA15 dually rear, 10' flatbed w/boxes 1961 V-206 Van Pelt open cab firetruck w/ 549 V8 5spd |
#32
Interesting regarding the Delvac 15w40 reccomendation. The '74 100 I'm bringing back to life has service records showing just that oil being used. I talked to a friend of mine who sells Mobil (since there isn't a convenient store near here to buy it from) and he felt, as I did, that it would be too heavy and to go with 10w30. (what I've always used in everything else) He hasn't brought me the oil, and this has me second guessing. Now, I have the AMC 258 so maybe it won't be as neccesary? I figured I would stick with Mobil at least, no sense changing now.
#33
Got it for $350. Seems to really only have 36k miles on it Its a 1975 150 4x4 Omaha Orange I think , Black interior. No Major rustouts on the body as far as I can see. So now I gotta figure out how to get her home 250 miles. Maybe tow it with a big rope behind the scout slooooowly
1975 All Wheel Drive 150 Omaha Orange 1979 Scout II Rallye Sunburst Yellow |
#34
As stated in post 31 there may be some issue with the brakes after sitting for so long. So I would be cautious about towing it with a rope/chain. The "towed" vehicle will need to stop the "towing" vehicle.
It sounds like you are limited on budget getting it home(hate to spend more getting it home than you did on the truck) I have been there in my younger days and did somethings that were not very smart. just be careful in what ever method you use.
President Gulf Coast Binders 75 SII 304 4 speed 65 80 152 3 speed 77 SII 345 Automatic 75 SII NO engine or trans 74 3/4 ton Wagonmaster 392IC 4 speed 4x4 74 SII 196 4 speed 76 SII 196 4 speed 80 SII turbo diesel 4 speed Last edited by Fred Demmon; 05-07-2009 at 06:31 AM. |
#35
* "Sick, twisted, psychopaths are sick, twisted psychopaths, no matter which god they worship." - seen on a blog * 2 '79 Travelers, 345, Torqueflight, D44's, (pretty standard) |
#36
I always like to squirt some marvel mystery oil into each cylinder before cranking an engine that has sat. Pull the plugs add a couple good squirts with an oiling can turn her over by hand a few times and try to fire her. Guess everyone has there own methods.
72 scout II trail rig .SOA 266,t-19 wide, dana 300,linked rear 92 Dodge 250 4x4 12 vavle Cummins. Stock...... for now....... http://oldironoffroad.com/ http://www.southeastbinders.com/ |
#37
I am considering priming the engine with a drill motor and 1.5 gals of marvel mystery oil after I drain whats in there. Then drain the marvel mystery oil and add 5w30 for the initial fire up and initial warm up. Drain again and then run a proper zinc oil after she is up and running. Maybe thats overkill.
I am brainstorming still about the safest way to get it home. Anyone know of a equipment rental place that might have a proper truck and trailer setup? Penske and Uhaul trailers are too small for the job according to their websites.
#38
The problem was you were honest.
You have to tell them you are towing a ford ranger not an IH.
#39
The only suitable Mobil products are the Delvac, the Mobil 1 "high mileage" 10-40 and 20-50 only, and 30wt. Last edited by Eric VanBuren; 05-07-2009 at 10:32 AM. |
#40
I concur with Bill USN-1; you have to tell them you are towing a ranger or light car (Neon is one I've used before) and they'll look at your tow rig & let you have at it. I've moved 3 scouts this way before getting my own trailer in the past year.
Good luck & drive safe.
'74 Scout II Plow Truck "Da Biter" '72 Scout SII - Bumble Bee '66 Scout 800 Sport - Parts Rig (Frame remains) '69 Scout 800A "Black Widow" - SOLD '63 Scout 80 Dually -(SOLD) |
| 100 , 110 , 1100 , 1300 , air filter , bar , bearings , brakes , bushing , cam , carb , diesel , distributor , engine , filter , front , ground , ignition , number , oil , power , radiator , start , switch , zinc |
