Old 04-29-2009, 03:31 AM
Rusty Scout's Avatar
Rusty Scout Rusty Scout is offline
Send a message via Yahoo to Rusty Scout
Default checklist for getting a barnfind up and running
I may be headed for Nevada this weekend to investigate and possibly retrieve a possible barnfind. Its a 1975 4x4 with an auto trans. The fellow selling claims it was running ok 3 years ago. Its been sitting since.
I am thinking my barnfind kit should include:
a fresh battery
5 gals on gas
oil, atf, brake fluid, water, 90wt
points, rotor, cap autolite plugs (did a 1975 with a 345 have points or a goldbox)?
spark plugs
timing light, dwell meter,
test light
Is there anything else I should bring for an ih truck thats been sitting for 3 years?
1975 All Wheel Drive 150 Omaha Orange
1979 Scout II Rallye Sunburst Yellow
Old 04-29-2009, 03:37 AM
Steve Grant Steve Grant is offline
Default Re: checklist for getting a barnfind up and running
Thats cool you found that truck. I'm heading out of town this weekend to drive home a '73 T'all 4x4. I would add fire extuinguisher to that list.
Old 04-29-2009, 05:13 AM
Fix a flat or an air tank for the likely flat tires. roll of duct tape and electrical tape, roll of 14 or 16 gauge wire and various connectors (likely to be mouse modified wiring) a spare carb would be great if you have one, beer.
Old 04-29-2009, 05:27 AM
If its a 75 it would not have points,but since you said 1100,its not a 75,or a 74 they where 100 and 150.1100 is 73 and back(when it was built not nessicarily what the title states)73 would have points(holly curved style most likely)
Old 04-29-2009, 05:44 AM
my mistake on saying it is an 1100. I don't know if it is a 1/2 ton yet but I have a feeling it is. According to the owner it is a 1975 4x4 pickup with a v8 auto trans but not getting much more info than that. So that means it could be a 100, 150 or 200 right? with a 304, 345 or 392?
Old 04-29-2009, 05:59 AM
Thanks for the input everyone. I have a good feeling about this one. (famous last words)
updated barnfind rescue checklist
a fresh battery
5 gals on gas
spark plugs
test light
beer.
fire extuinguisher
Old 04-29-2009, 07:29 AM
Selkirk's Avatar
Selkirk Selkirk is offline
Send a message via AIM to Selkirk
If you have any spark plug wires, I would sure throw those in also. Mice love them.
Also jumper cables if the spare battery runs down.
Selkirk
1975 Scout ll XLC 4x4, 345, 727
1975 200 P/U 4x4, 392IC, NP205, T36, D44/D60
1975 150 P/U 4x4, 392IC, NP205, 727, D44/D60
Old 04-29-2009, 07:33 AM
Elijah G's Avatar
Elijah G Elijah G is offline
Wd40
77 Terra 345/727/20/d44s soa
69 800A 304 and 4sp
Bad decisions come from a lack of experience, most experience comes from bad decisions.
North Texas Binders member!!!
Henry Ford: "Failure is simply the opportunity to begin again, this time more intelligently."
Old 04-29-2009, 07:48 AM
Paul Morgan Paul Morgan is offline
Banned
Don't try to run it off the gas tank
Disconnect before the fuel pump and stick it in a fresh can of gas
Old 04-29-2009, 08:01 AM
Fred Demmon's Avatar
starting fluid
President
Gulf Coast Binders
75 SII 304 4 speed
65 80 152 3 speed
77 SII 345 Automatic
75 SII NO engine or trans
74 SII 196 4 speed
76 SII 196 4 speed
80 SII turbo diesel 4 speed
100 , 110 , 1100 , 1300 , air filter , bar , bearings , brakes , bushing , cam , carb , diesel , distributor , engine , filter , front , ground , ignition , number , oil , power , radiator , start , switch , zinc
