Go Back   Binder Planet Forums > IH Clubs > Member-Club Forums > Gulf Coast Binders
Old 03-05-2009, 09:17 AM
Paul Morgan Paul Morgan is offline
Banned
Default Re: Members Rides
Adam said he uses a PPG product also for the primer
Just say no to the spray can lol
As far as the diamond plate goes, you can use the 3M panel adhesive
I forgot the number, its like 4100 or 5100
You don't have to use it on the top, you use it between the panels
On the top you could run seam sealer
You can use sheet metal screws, but I think I'm just going to lay it in and weigh it down along the seams with scrap metal or parts until it dries
Old 03-05-2009, 09:24 AM
RailRiderHD's Avatar
RailRiderHD RailRiderHD is offline
Dont listen to Paul,, he has issues we all would take years to understand ha ha. Definetly use a paint gun to primer, you will be much happier, it'll take you forever to prime the whole scout with a can and will never be even, lots of runs, but if you use a paint gun with a good primer and reducer it will turn out way better and way faster. Remember with a paint gun you can control your flow and pattern, spray can......not so much.
1979 Scout II 4x4
345 with auto tranny
16 inch baja 2's
285 nittos
4 inch rough country lift
One solid IH!
Old 03-05-2009, 10:23 AM
sullyscout77's Avatar
I was planning on tearing the old rusty deck out completely, but now you got me wondering if I would be compromising the structural fortitude of the tub by going back with merely aluminum diamond plate. Dirk, you're the Engineer amongst us. What's your take on this? My deck plate is only seriously non-existent along the fender wells and by the tailgate. Should I remove all rust, prime and sandwich for the strength, or "gut the pig", ?
Sully
Old 03-05-2009, 11:20 AM
Fred Demmon's Avatar
Here is the fleet
75 SII
65 80
77 SII
75 SII
73 SII
President
Gulf Coast Binders
75 SII 304 4 speed
65 80 152 3 speed
77 SII 345 Automatic
75 SII NO engine or trans
74 SII 196 4 speed
76 SII 196 4 speed
80 SII turbo diesel 4 speed
Old 03-05-2009, 01:39 PM
Dirk Kolnsberg's Avatar
Dirk Kolnsberg Dirk Kolnsberg is offline
Send a message via AIM to Dirk Kolnsberg Send a message via MSN to Dirk Kolnsberg
Sully,
I started a new thread for paint and body work discussions and posted some of my quick thoughts there. Take a look and let me know if it helps.
http://www.binderplanet.com/forums/s...504#post560504
Dirk
Member - Gulf Coast Binders
1966 4x4 Travelette
1966 Stepside Pickup
1966 Scout 800 Sportop
1967 Scout 800
1970 Travelall - Project TraveLow
1971 Travelall
1974 4x4 Pickup
1976 Terra - Project First Degree
1977 Scout II - Project JPEater
1977 SSII
Old 03-05-2009, 05:34 PM
Dirk, The stance on Jeepeater is really stout! How did you overcome the typical "scout sag" in the rear? I noticed that most sag like mine, but J/E looks "jacked-up". Was this the "custom-order" springs you had mentioned or have you added on since then? Also a little more info on the "pimped-out" wheels & skins.
Sully
Old 03-05-2009, 08:11 PM
Default Saggy rear?
As you can see from the first picture, I too had the saggy rear syndrome at one time. Through some minor surgery, a little bit of lifting and spring repositioning my rear now sits nice and high and is the envy of many Scout owners .
Right now according to one of the main body lines down the side of the Scout, running about door handle height, it sits about 2 1/2" high in the rear. Although I like the look that is a little too much for me, so I need to level it out about an inch or so. The reason it sits higher right now is that in the rear I did a spring over with stock springs and used Ruff Stuff Specialty anti-axle wrap style spring pads that add another inch or so compared to the original spring under pads. I still have to put in the rear seat, finish the rear bumper, build a tire carrier and a 35" spare to mount up that will all add weight to the rear and bring it down some. On the front I have the original Alcan Spring lift springs (thanks for letting me keep them for mock up Holt) in a spring under now but will probably move up to a little taller spring to get everything dialed in where I want it.
As for the wheels and tires, while I liked the sleeper look of the black rims I wanted a little more flash and dazzle. Off came the 33 X 12.5 X 15 ProComp mud terrains on 15 X 8 Rockcrawler steel rims and on went the fancy 35 X 12.5 X 17 BFG new style mud terrains and 17 X 9 ProComp aluminum rims. I like the look as to me it helps tie together all the custom work and compliments the go fast shiney bits under the hood.
1966 4x4 Travelette
1967 Scout 800
1971 Travelall
1974 4x4 Pickup
1977 SSII
Old 03-05-2009, 11:16 PM
Banned
Hey Dirk,
Fill up a big aluminum box in the rear like BillUSN1, that will drop your rear end (that's highly sought after and admired) down an inch or so
Check out Bill's thread for being prepared
Dude was definitely a Boy Scout LOL
Also, if you haven't already, read through Bill's threads on EFI, he wrote the book on budget IH
Old 03-06-2009, 06:41 PM
WRECKTHOSECARS's Avatar
WRECKTHOSECARS WRECKTHOSECARS is offline
let's see some more!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Support Language, Borders & Culture
http://www.binderplanet.com/forums/s...ad.php?t=89655
75 Scout II - under construction
Old 03-09-2009, 10:47 AM
Banned
Where's the rest of the crowd's pics
1967 , 345 , 800 , aluminum , axle , binderplanet , body , build , custom , door , front , gear , lift , paint , photos , pickup , pictures , project , scout , spring lift , tires , truck , website , wheels , windshield
