I am restoring a 1977 SSII (http://www.binderplanet.com/forums/s...ad.php?t=85751) and am having trouble finding the frame VIN number. I have been told that it is on the top or side of the frame near the firewall on the drivers side but I do not see it there. I have a second 1977 SSII (http://www.binderplanet.com/forums/s...ad.php?t=82887) as well and I don't see a VIN on its frame either. Am I just looking in the wrong place or is there not a frame VIN number on Scout IIs?
"It was running when it was parked and has typical scout rust"
Hey Mike
I just cleaned the hell out of my frame along the driver's side along the outside frame rail right behind the wheel I don't know if it's the same on a SS but that was on a 74 SII |
On the Scout II (incl. SS-II), the *partial* VIN is stamped on the frame: on the driver's side, if you look at the vertical aspect of the frame that is visible in the front wheelwell behind the tire tread and in front of the firewall/floorpan.
It is the last 8 digits of the VIN.
'75 & '76 Scout IIs Amateur radio operator, General Class - K6IHC Work Smart, Not Hard... |
Mike Moore www.ScoutcoProducts.com ______________ 1980 Scout II-Chevy LT1, 700r4, NP241, 3.73's, RS, 4" lift, 31's. Daily driver __________________
Scout LT1 swap: $3055 Leaving a riced out Honda with a fartpipe sitting at the stoplight: Priceless! |
On my 79 ssII i found a stamped # under the rear bumper mounting plate on the frame. Not sure if was the vin?
I FOUND IT!! It took a while and it is nothing like I expected it to be, but sure enough there was all along. It is on the outside driver's front frame rail, just in front of the fire wall. You can see the frame hook slot just at the right of this picture. I outlined it with a red sharpie to make it stand out for this picture. Thanks for everyone's help.
Dude, that's where I said it was
Good job Mike!
You beat me to it. I've been trying to locate the frame VIN since the last meeting.MacIan |
A buddy of mine has moved to Texas and his Scout is registered here in Wasington. The frame and body are two Scouts. He removed the body VIN plate when he painted (rhino liner in and out) it. What will Texas want when he moves the Scout down there? He has all titles and the proper VIN plate for the body, but it is differant then frame.
What should he do? What do they inspect on out of state vehicles?
Rustless 1973 IH Scout II six cylinder. ![]() 1974 IH Scout II six cylinder four speed off road project with 3/4 ton axles. Need Hummer Wheels!
Couple years ago friend bought a car in Illinois and brought it here. Said he went down to the DMV showed the title and insurance. Filled out a couple papers and gave them money. Pretty easy he said. Still has the title from Illinois.
Will have to have a state inspection. Has to be reg and insurance. 20 years and older is saftey and parameters. Original smog if so equiped and the basics. Lights, horn, emergency brake.
77 Terra 345/727/20/d44s soa 69 800A 304 and 4sp Bad decisions come from a lack of experience, most experience comes from bad decisions. North Texas Binders member!!! Henry Ford: "Failure is simply the opportunity to begin again, this time more intelligently." Last edited by Elijah G; 03-10-2009 at 09:30 AM. |
| 1977 , binderplanet , body , brake , frame , front , illinois , lights , number , scout , scout ii , ssii , top |
