Go Back   Binder Planet Forums > Special Interest Groups > Triple Diamond Trucks > IHC Military Vehicles
Old 10-12-2010, 01:16 PM
Dave Ball's Avatar
Dave Ball Dave Ball is offline
Default Re: M-Truck helpful part numbers and parts sources
There is some xover between military vehicles. here is one hint... IHC used Delco electrics on the M trucks... So did GMC, Chevy and Studebaker to name a few.
Some of the gauges are the same for Mack, Reo and Autocar.
1944 USMC IHC M-5H-6 3 ton cargo truck
1944 USMC M-2-4
1943 USMC M-2-4
1944 USMC Henry Spen trailer
1942 WC-56 Dodge Command Car
1942 Dodge WC-55
1961 Dodge Power Wagon
1962 USMC M416 1/4 ton trailer
1965 M101A1 3/4 ton trailer
Take Care
Dave Ball
Saratoga California
Old 10-12-2010, 02:58 PM
denubilo denubilo is offline
Any body got a good source for Carb and fuel pumps and kits?
I want to buy a spare carb for my M-2
And rebuild the one I have
Paul
Old 11-29-2010, 02:46 PM
Found great place for carb kits
H & M Industrial Supply Inc
20730 Dearborn Street
Chatsworth, CA 91311
Phone: 800-346-4331 Amy
Fax: 818-718-9211
63AW-10 kit k2018 $48.45
63AW-11 K2024 $43.00
Old 11-30-2010, 08:11 PM
hanselandgretel hanselandgretel is offline
Paul and all (that even rhymes!). I'll help with a chart for the M5, don't know anything about the mini-trucks you guys are working on! I have found sources for a lot of parts and rebuilds in my M5 restoration process, some of which will work for the smaller stuff.
Old 12-01-2010, 01:05 AM
It is not just size that counts you know!!!
Any help finding part numbers is always appreciated.
Paul
Old 12-01-2010, 11:18 AM
Dave Ball's Avatar
Are you sure?
Its been my luck to have tried out all three, the small M2, medium M3 and the much bigger M5.
There is really only one big International, and it is by far the most fun to drive the big boy, it is not like the smaller trucks that tip toe around and get confused with Dodge or Chevy trucks.
It is much bigger than a CCKW and with the proper bed looks huge sitting next to one.
There is a very big difference in the sound as well the big Red Diamond that rumbles along and has the power to pull a house, while the M3 runs so smooth you are not sure it is running and the M2 sounds like a singer sewing machine.
Lots of people are turned off by what appears to be a big maintenance task when looking at the M5 but here is a secret everything that is on the smaller trucks except the extra fuel tank and third axle is exactly the same amount of work.
And once the brakes are done the maintence is very close to the same amount of work as a two axle truck.
I think size does matter!
1944 USMC M-2-4
1943 USMC M-2-4
1942 Dodge WC-55
Take Care
Dave Ball
Saratoga California
Old 12-01-2010, 11:55 AM
I wasn't talking about trucks!!!
Old 12-01-2010, 06:53 PM
Dave Ball's Avatar
I knew that Paul I got the jest in the vernacular, I just wanted to clear the air on the M5. Many collectors probably don't know how similar the trucks are to take care of and just see the M5 as a big beast with $2500 worth of tires.
1944 USMC M-2-4
1943 USMC M-2-4
1942 Dodge WC-55
Take Care
Dave Ball
Saratoga California
Old 12-09-2010, 11:43 PM
Colin Rush's Avatar
Colin Rush Colin Rush is offline
Man of Voive
Default M-2-4 Fuel Tank Sender Gasket
The M-2-4 uses a fuel tank sender that is secured with six screws. The original part number is 63474H.
The Scout 80 & 800 also use a sender with six screws. The Scout 80 parts book lists the part number as 967074R1. It also has a note "Will work for 63474H."
967074R1 is still available from International Truck as a new part. When I called tonight, Brattain International had three on the shelf. It is also available from the Light Line dealers. I haven't called to check, but I suspect it is also available from the CaseIH dealers.
This is also available from the Jeep and Kaiser parts dealers as an Omix-Ada part, PN 17725.02, to replace the Jeep PN 635641, which is for a 1955-1965 Jeep CJ-5.
"The red stuff runs if you promise to use it". -Mike Kowash (died 24 APR 10)
Old 12-10-2010, 12:46 AM
Dave Ball's Avatar
There most probably is a gauge, voltage difference nothing some calibration and a resistor won't fix.
1944 USMC M-2-4
1943 USMC M-2-4
1942 Dodge WC-55
Take Care
Dave Ball
Saratoga California
bearings , binderplanet , case , cylinder , engine , filter , ground , ihc , m-2-4 , master , number , oil , part , parts , pictures , plug , project , rebuild , repair , reproduction , scout , spark , transmission , truck , windshield
