Go Back   Binder Planet Forums > Special Interest Groups > Triple Diamond Trucks > IHC Military Vehicles
Old 12-17-2008, 09:00 AM
John Donnelly's Avatar
Administrator
Default M-Truck helpful part numbers and parts sources
Here is a thread for posting valid part numbers and parts sources for IHC M-trucks.
Please post what vehicle the part fits, or if it fits all models.
-John
Old 01-14-2009, 08:06 PM
rich eardley rich eardley is offline
Default Re: M-Truck helpful part numbers and parts sources
www.restorationsspecialties.com they have weather striping and clips for about every thing
Old 01-15-2009, 12:25 PM
Sean Nichols's Avatar
Sean Nichols Sean Nichols is offline
Correction on the above link:
http://www.restorationspecialties.com/
Sean Nichols
'42 IHC FFN-3 Crash Truck (under restoration)
'71 AM General M151A2
'85 M1038 HMMWV
Old 02-02-2009, 01:23 PM
Dave Ball's Avatar
Dave Ball Dave Ball is offline
New Teflon & Rubber Valve Stem Seals
Perfect Circle #VS-6
RD372 RD406 RD450 FBB450 FBC450 RD501 engine.
Nominal Stem Diameter .434" - Outer Diameter .625".
1944 USMC IHC M-5H-6 3 ton cargo truck
1944 USMC M-2-4
1943 USMC M-2-4
1944 USMC Henry Spen trailer
1942 WC-56 Dodge Command Car
1942 Dodge WC-55
1961 Dodge Power Wagon
1962 USMC M416 1/4 ton trailer
1965 M101A1 3/4 ton trailer
Take Care
Dave Ball
Saratoga California
Old 08-17-2009, 05:00 PM
denubilo denubilo is offline
John,
I wonder if everyone is willing to share the sources for work and parts.
I am attaching a sample of the word chart that could be built.
Start with common needed items then let it grow to sources for rebuilding gens, etc.
Paul
Old 11-12-2009, 09:46 PM
Colin Rush's Avatar
Colin Rush Colin Rush is offline
Man of Voive
Default Oil Filter Element Part Numbers
Here is the link to the thread listing current part numbers for oil filter elements for the original M-2-4 and M-5H-6 engines. M-2-4 is post #12, and the M-5H-6 is post #11.
I believe the M-1-4 used the same filter as the M-2-4.
If someone gives me the original part number for the engines used in the M-3-4 (L&H) trucks and the M-5-6 trucks, I can do the same for them.
"The red stuff runs if you promise to use it". -Mike Kowash (died 24 APR 10)
Old 12-18-2009, 11:44 AM
NOS fuel gauge on e-bay
200417843402
Paul
Old 12-18-2009, 03:04 PM
Dave Ball's Avatar
Got to be careful on ePay, sometimes the parts listed as IHC are for an obscure vehicle, like a K8 dump thats has a 6 volt negitive ground system and uses a sending unit for a 36 gallon tank that only that guage will work with as a matched pair. I learned this the hard way when I bought an NOS sending unit off epay, it would read 3/4 of a tank when full. I did finially figure out the perfect bend in the float arm, and it was a pain in the tookus.
Last week I saw someone buy an nos throwout bearing listed for an M2 on ePay, it closed at $64 dollars after a couple of enterprising collectors bid it up at the end. This bearing probably has dried up grease in it and is worthless, because its a sealed unit, it will be a screamer you can count on it probably two months after you remove the transmission and slide it on with a smile. Just a couple weeks back I took a couple of takeoff throw out bearings down to B&A friction there a clutch shop here in San Jose they pushed off the old bearing and pressed on a new bearing on two for $47 dollars out the door.
Becareful on ebay sometimes rebuilt fresh beats unknown NOS old junk thats been sitting in a mud puddle for 65 years.
I went and looked at the guage it looks like the right type and light tan for the early M2-M3-M5 trucks and the part number looks like a K5-K8 style.
So it may be a good find. Untested as it may be.
1944 USMC M-2-4
1943 USMC M-2-4
1942 Dodge WC-55
Take Care
Dave Ball
Saratoga California
Old 06-14-2010, 09:05 PM
hanselandgretel hanselandgretel is offline
M5H6 Master Cylinder, new, Raybestos MC2842, about $175.
Old 07-10-2010, 12:43 AM
Dave Ball's Avatar
Anyone have any leads on internal parts for the M-2-4 transfer case?
1944 USMC M-2-4
1943 USMC M-2-4
1942 Dodge WC-55
Take Care
Dave Ball
Saratoga California
bearings , binderplanet , case , cylinder , engine , filter , ground , ihc , m-2-4 , master , number , oil , part , parts , pictures , plug , project , rebuild , repair , reproduction , scout , spark , transmission , truck , windshield
