  #131
Old 06-11-2012, 11:55 AM
Mark Ashford's Avatar
Mark Ashford Mark Ashford is online now
Moderator.. or something
Default Re: Lil' Pink Scout
No video??? :lame:
Nice job. I got less than a week now to get mine back up and running so I can beat on it fathers day. The frame bend is worse than I though, Causing about a 2" difference on were the air cleaner is SUPPOSED to stick through the hood and were it does
And its got to make it thought 4 more races
  #132
Old 06-11-2012, 12:02 PM
Monte Lauer's Avatar
Monte Lauer Monte Lauer is offline
Originally Posted by Mark Ashford View Post
No video??? :lame:
Run it till it breaks!!!
I posted video links and I just edited them and made them bigger so you can't miss them now.
1971 810 Scout II Trail Rig "Orange"
1977 Scout II Mud/Sand drag rig "Lil' Pink Scout"
1975 Scout II Daily Driver "Leonidas"
http://www.totaldestructionracingteam.com
http://www.ihsto.org
  #133
Old 06-11-2012, 04:22 PM
thats kind of the plan ... we'll see if it holds out. Problem is its also pulling the rad toward the motor, making my current project of installing an electric fan more difficult... so I might just be ******* the inner fenders sooner than later (I was trying to keep them for class reasons).
  #134
Old 06-11-2012, 06:07 PM
On the flames It looks like you painded with multi layers with multi colors,could you tell me what colors you used,I realy like the way it turned out
  #135
Old 06-12-2012, 08:40 AM
I can't remember the exact paint code numbers but the flames were painted with the stock Geo Tracker Pink. After the base coat and the flames were painted we sprayed it with a candy tinted clear coat to give it the pink finish.
  #136
Old 06-12-2012, 08:42 AM
I mounted one of the new tires last night.
  #137
Old 07-02-2012, 09:28 AM
I had a blast on Saturday, I almost forgot what it felt like to race. The new engine runs awesome but now I am having some tranny trouble. The transmission is stuck in low gear and won't shift, I am hoping it is an easy fix.
Lil Pink Scout Willamina Mud Drags 2012
Lil Pink Scout Gopro footage Willamina Mud Drags 2012 - YouTube
Lil Pink Scout Willamina Mud Drags 2012 - YouTube
  #138
Old 07-12-2012, 11:49 AM
More video from Willamina...
The race where we broke the transmission.
  #139
Old 07-13-2012, 02:20 PM
orodos's Avatar
orodos orodos is offline
Awesome video with the Gopro! You really smoked that black truck in video #3!
Currently Scoutless
Deserve's got nothing to do with it.
  #140
Old 07-26-2012, 10:12 AM
After the Willamina race we had the transmission rebuilt, the front and rear clutches were welded together, I also replaced the transfer case, the front seal was leaking. We are headed to the Newport this weekend for a two day race, Hopefully there will be no more mishaps and we will bring home some plastic.
All loaded up and ready to go...
100 , 800 , axle , axles , bearings , build , build up , engine , filter , gear , glass , oil , pad , paint , power , project , s80 , scout , scout 80 , start , steering , throttle , top , tranny , truck
