Old 04-09-2008, 12:14 PM
Architectdave's Avatar
Architectdave Architectdave is offline
Default Dana 44 Front Axle Parts List
I am attempting to assemble a parts list that includes everything (parts numbers, cost and source) to rebuild a Danna 44 front.
I will be adding to this first post as people give me info.
That said starting from the outside in.
______________________________________________
Warn manual locking hubs.
Warn #9062
Brake Rotors
Napa 4885667
Wheel studs.
Caliper
Pads
Standard brake hose
Napa hose front 38538
Napa hose front 38539
4" lift brake hose
Dana 44 front wheel bearing seal
NAPA 23300
National 442874
CR 23300
Victor 46467
DANA 44 FRONT SPINDLE BEARING KIT
Dana 706527X
Includes:
(1) B-2110 Torrington Bearing
(1) Nylon Axle Thrust Washer
(1) 722108 Axle Stub Seal
(1) 722109 V-Ring Spindle Seal
NAPA BK1
spindle/nut
thread = 1 5/8”-16
Doorman 05304 or 615-126 (I believe both are the whole kit)
Pik-A-Nut 305304.1
NAPA 630-1654
Spindle nut - Auto lockers
Spindle needle bearing
B-2110
Dana 44 front axleshaft U-joints
Carquest 1-0297
Spicer 5-297X
Ball Joint lower-Ball Joint Upper
LINK
One side complete $42.00 both upper and lower
Stock tie rod ends.
Moog ES2052R (coarse thread) 12 TPI
Moog ES2053R (fine thread) 18 TPI
Dana 44 front axle inner seal
(at diff) CR 13165
National 5131
Front Dana 44 wheel bearings
Inner Timken SET 47 Cone LM102949 Cup LM102910
Outer Timken SET 45 Industry no. A35 Cone LM501349 Cup LM501310
Carrier Bearings
Pinion Bearing
Pinion Seal
Diff Cover Gasket Seal
U-BOLTS
Scout II w/ Dana 44 front axle
Front Superlift P/N 5944 contains (2) 10162, (1) 10112, (1) 10122
Lube oil - type and quantity
Types of carriers and lockers people like.
Let me know what I forgot.
Calling an illegal alien an 'undocumented immigrant' is like calling a drug dealer an 'unlicensed pharmacist'
73 scout II - AMC 258 - Holley 390 Offey Manifold - HEI Coil in cap Dizzy - 3 speed - D30 -D44 - Factory orange with white soft top
Old 04-09-2008, 12:37 PM
George Womack's Avatar
Default Re: Dana 44 Front Axle Parts List
Here are a few part numbers I copy/pasted from my files:
Dana 44 front wheel bearing seal NAPA 23300
National 442874
CR 23300
Victor 46467
Dana 44 front axle inner seal (at diff) CR 13165
National 5131
Spindle needle bearing B-2110
FRONT SPINDLE NUT
spindle/nut thread = 1 5/8”-16
Pik-A-Nut 305304.1
NAPA 630-1654
or NAPA 630-1657 for the full spindle nut kit (2 nuts, thrust washer and bend-over washer).
Chevy type spindle nut kit NAPA 630-1653
Dana 706527X
Includes:
NAPA BK1
Dana 44 front axleshaft U-joints Carquest 1-0297
Spicer 5-297X
U-BOLTS
Stock tie rod ends.
90% of all stats are made up.
Old 04-09-2008, 01:56 PM
baveryt baveryt is offline
Just purchased the following from NAPA
Rotors number 4885667
Brake hose front 38538
Brake hose front 38539
These are both standard length hoses, not sure which is left or right, just happen to have the receipt in my pocket.
Also bought calipers, will check part numbers whem I get home
Old 04-10-2008, 04:44 AM
Awesome keep them coming guys.
Old 09-02-2008, 01:39 PM
Anyone have a cross reference to another application for these? The counter clowns cant seem to find them.....
Scout II tierod ends.
Old 09-02-2008, 01:47 PM
bigmookied's Avatar
bigmookied bigmookied is offline
an old post on TRE's
http://www.binderplanet.com/forums/s...ad.php?t=47020
The proper MOOG number is ES2052R for the coarse-thread part (driver side) and ES2053R for the fine-thread part (passenger side). This is for the 4X4 Scout II with either a Dana 30 (FA-13) or Dana 44 (FA-43 or FA-44) front axle. NAPA no longer carries the coarse thread version, but any shop that can get MOOG parts should be able to order one. (e.g., Big A, Parts Plus, Autozone, Carquest or Checker).
The coarse thread is 12 TPI, the fine thread is 18 TPI.
Moog, and TRW show part numbers for both the 2052 and the 2053 (both sides).
McQuay Norris shows only the 2052.
Scout Light Line Dealers have these parts available under the IH numbers:
459307C91 Left/Driver
459308C91 Right/Passenger
1969 Travelall 1200D 3/4 ton 4 X 4 345 - 4 BBL Carter 500 - MSD Ignition - Auto Trans IH D60/Cheby D44 -Disc Brakes all around 6" Cheby spring lift
Panties, not the best thing on earth, but next to it!!
Old 04-24-2010, 06:01 PM
BennettMoe's Avatar
BennettMoe BennettMoe is offline
The side gear thrust washer is DS 32121 according to Randy's Ring and Pinion.
http://www.ringpinion.com/ProductDet...px?ProdID=5986
Here also is a handy list of vehicles that used the D44.
'53 R-112 'Phantom'
'70 1100 4x4 '#3' parts
'74 200 4x4 'Heavy D'
'78 Scout II 'Mr. Hanky'
plus a '63 Stude, '65 Valiant conv, '56 Porsche replica, SRT6
...is that enough?
Logging progress on Mr. Hanky here:
www.mrhankscout.blogspot.com
Triple Diamond Fourwheelers
110 , 4x4 , axle , ball joint , binderplanet , brake , brake hose , dana 44 , diff , front , gear , lift , number , oil , part , parts , rebuild , scout , scout ii , tie rod , warn
