Old 12-26-2007, 01:28 PM
79scout-too 79scout-too is offline
Default Auto to Manual T case location?
I searched around and only found one thread where some one said that they were 99.9% sure that the transfer case is in the same spot when changing from auto to manual transmission.
Can anyone verify this for me?
I just want to make sure because I have a lot of variables due to chevy axles, SOA, lift springs and tranny swap.
Thanks!
Old 12-26-2007, 07:23 PM
WRENCH MAN's Avatar
Default Re: Auto to Manual T case location?
I believe that the transfer case is about 7/8" farther to the rear than with a 4spd manual.
68 Rambler American
72 1210 4x4
77 ScoutII
97 JEEP TJ
99 Yamaha YFS 200 (248)
Old 12-26-2007, 09:30 PM
Alright thanks. So if I set my pinion angles with an auto it shouldn't be a concern when I swap to a manual.
axles , case , lift , soa , tranny , transmission
