Old 11-17-2007, 02:41 PM
Mastiff's Avatar
Mastiff Mastiff is offline
Default Scout 80 light switch
What is the box thing hanging off the light switch? Is it a fuse of some kind? I'm talking about the two terminal thing attached to the back where the main power comes in.
1965 Scout 80, D44/D27, 152/T90/D18
Status: Motor, trans, axles, brakes, T-case all rebuilt. Lift and 32" tires installed.
Still need: Skid plates, bumpers, locker(s), winch, better seats.
Looking for: Scout 800 flanged D44, maybe Scout II axles.
Old 11-17-2007, 06:57 PM
timscout1's Avatar
timscout1 timscout1 is offline
Default Re: Scout 80 light switch
It is the circuit breaker for the headlights, The power lead goes on the outer terminal
choose IH and fly with quality under your belt.
73 1210 4x4 Travelette 5 spd. 392
300 utility tractor
64 Scout 80-152/ weber 32/36
1955 IH RC180 cabover 7.3L
1947 IH fire engine GD233
1970 Fleetstar 2010 fire engine LV549
73 Scout2, 304.4 spd.
Member, Sonora Desert Scouts
Old 11-17-2007, 08:05 PM
Mastiff's Avatar
Thanks. Is it replaceable if it blows? What's the amp rating?
Old 11-17-2007, 10:10 PM
David Wilcox David Wilcox is offline
It is a self reseting thermal circuit breaker typically 20-30 amps. The value should be stamped into the metal housing, although that is not always true. They do wear out over time and will start tripping lights off then when it cools off they come on again, I had another vehicle that did that and replacing the thermal breaker fixed it.
Dave Wilcox
64' Scout 80
Old 11-18-2007, 06:38 AM
Mastiff's Avatar
Thanks for the help.
Old 02-18-2009, 11:36 PM
kingben01's Avatar
kingben01 kingben01 is offline
I have a 30 amp breaker I'm about to install in mine. Anyone think this is too high? I haven't checked the amp draw on the head lights, but if I remember correctly, it's around 20 - 25 amps. So, I guess what I'm really asking is....Does anyone here think the 62 scout 80 wiring CAN'T handle 30 amps in the headlight circuit?
By the way, my wiring is stock, but in very good condition....
62 Scout 80/152/t-90/Dana 18/27 front/offset 44 rear
Also known as "4byfourbyeIV" on JustIH.com
Isn't it funny how we never have time to do it right, but we always have time to do it again......
Old 02-19-2009, 10:08 AM
George Womack's Avatar
This circuit breaker protects all the lighting circuits, not just the headlights.
kingben, you'll be fine with a 30A breaker.
90% of all stats are made up.
Old 02-19-2009, 06:55 PM
kingben01's Avatar
Thank you george. I always apprectiate your insight.
headlights , light switch , lights , power , scout , scout 80 , start , switch , wiring
