Old 10-25-2007, 10:40 PM
ktsno1's Avatar
ktsno1 ktsno1 is offline
Send a message via AIM to ktsno1
Default 800 pros
dont know too much about 800's (i got 2 II's) so i got some questions.
before i ask, i have searched and but i cant seem to find exact answers to my quetions.
if you know of a post feel free to tell me which one.
1. where is the fuse box in a 800?
2. how many body mounts are there? ( one in the rear by the tail gate. and one behind the seets, the one where your feet would be. where else?)
3. how is are the fuel lines mounted to the tanks?
4. best way to fix frozzen ebake line?
5. i know all about rockers on scoutIIs but what is the rocker set up on an 800? (the one i am looking at only has outer but i think the inners are just non existant)
6. is it hard to put the back seet from a scout II in an 800?
7. small shackel lift on an 800... what are the side effects?
8. how much does an 800 weigh with 266 and 4 speed hard top. stock?
thanks guys
75 scout II XLC 345, 2brrl, T-15D, Dana 20, Dana 44's, Metalic blue paint, soft top, cd, cb, CJ rims.
68 Scout 800 266 4speed. hard top. d44 rear skid plate,some body work to make it legal, cherry bomb duals, tracker gas tank in rear, cheep bedlinered outside.
Old 10-25-2007, 11:48 PM
Rex A. Reed Rex A. Reed is offline
Default Re: 800 pros
There is no fuse box; this I know. I don't have answers for your other questions without some looking and pondering.
1970 Scout 800A (Military - U.S. Army Contract)
196 Cu. In, T18
Dana 20, 4.27:1, D44/30
1966 Scout 800
152 Cu. In., 4 Speed
Dana 20 twin stick, PTO Ramsey winch
Dana 27 axles
Farmall 504 Diesel, 1966ish.
Try not to get scared half to death twice!
Old 10-26-2007, 12:41 AM
Fuelsmech's Avatar
Fuelsmech Fuelsmech is offline
Send a message via Yahoo to Fuelsmech
there should be 2 body mounts for the front clip.
SSgt Thomas Case
Los Lunas, NM
79 Scout II 345/727/Dana 44s/-Papa Burgundy
Old 10-26-2007, 02:20 AM
rivastian rivastian is offline
Send a message via MSN to rivastian
and one more under the radiator. and if my count is correct should be 7 or 8 total.
Old 10-26-2007, 04:55 AM
Fuelsmech's Avatar
For useful info check out the FAQ's that has the body mounts in it.
http://www.binderplanet.com/forums/f...cfaq_body_lift
SSgt Thomas Case
Los Lunas, NM
Old 10-26-2007, 05:56 AM
Mark B 70SR2's Avatar
Mark B 70SR2 Mark B 70SR2 is offline
There are 9 mounting locations, One under the radiator, one on each side at your feet, and just behind where you sit, There are four at the rear, two of which are hiding behind plastic plugs in the back of the wheel well, and two in the bed (which may or may not be hiding under the metal in the bed)
......__________
.... |__________|
.[]<|0|_______|0|>[]
....|.... |.v....|.....|
....|___|.......|___|
Old 10-26-2007, 07:21 AM
ktsno1's Avatar
wow... thats alot of body mounts. ive seen pics of the one by the tail gate, the one behind the seets, and the ones where your feet would be. got any pics of the other ones?
no fuse box... that explanes alot... ok then... where are the fuses then?
another question... 9. the windshield wiper fluid pump and tank... are they the same as scout II's
thanks guys... i knew id find the pros
Old 10-26-2007, 08:01 AM
HillRaiser's Avatar
HillRaiser HillRaiser is offline
As some one already answer - there isn't one. Where are the fuses then? There are a couple of inline fuses under the dash near the instrument cluster and ignition switch. I added a couple of small (8 fuses each) fuse blocks that accept the blade-type fuses and wired my gauges, wiper (electric replacement), etc., to the fuse blocks.
One under the radiator. Two under your feet when sitting in the front seats. Two on the frame rails near the rear seat area. Four under the tailgate area. Good news though is the body seems to stay on fine without all of them in place. The ones under my feet are completely missing. The ones under the rear seat area have broken mounts. Working on fixing all of that, but the body hasn't flown/fallen off yet. :-)
The fuel lines run from a selector switch located behind the driver's seat on the floor to each individual tank. The fuel line enters the box/bay/whatever that holds the fuel tank from the front of the truck. It then goes under the fuel tank, between the fuel tank straps that hold it to the bottom of the fuel tank bay. The line then goes up the front of the tank, past the sending unit and into a port near the top of the tank. That line then runs down the inside of the tank and has a hockey stick bend at the bottom with a little fuel filter on it. I have one pulled out currently & can post a picture if you like.
I removed one end from the parking brake lever (i have a few pics of this process if needed) and the other end from the lever under the center of the truck. I soaked the whole length of the cable in rust dissolver (liquid wrench, pbblaster, etc.) and let it sit a while, did that again, waited, again, waited, then grabbed both ends of the cable with a pair of vice grips. Enlisting the aid of a not-so-happy-to-help wife, we alternated pulling on the cable. It barely moved at first and then slowly broke free. After applying more rust dissolver and wd-40, etc., I could move the cable freely from one end. Still working fine today - free'd it over a year ago.
1971 Scout 800B Comanche V304/T-39/D20/D30-D44 3.73/POWR LOK/32's/Pertronix/Hurst ProMatic-2/FlowMasters
1961 Scout 80
1972 IH Cadet 76 Lawn Tractor
Old 10-26-2007, 08:05 AM
HillRaiser's Avatar
Mine has a small spring and shackle lift - no negative side effects to report.
1961 Scout 80
Old 10-26-2007, 09:02 AM
rlireland's Avatar
There may be some inner rocker replacement s but most guys just fab their own out of 16ga stock. Gary Billings and other have done rocker work. They might chime in also.
I wouldn't recommend going over 2". And this presumes your front suspension parts (tie rod ends, spring bushings, etc) are in top condition. Otherwise, you're going to get wandering and stability problems.
thanks guys
Estimates have been given in various threads from 3600 to 4500 lbs for a V8 Scout 800. Why do you want to know? If you need an exact weight of YOUR Scout, it's best to get it weighed on a truck scale. Your local landfill or scrap yard will have one.
Roy
345 , 800 , axles , body , cable , fluid , front , frozen , panel , parts , pickup , pto , scout , scout 2 , scout 80 , scout 800 , scout ii , start , suspension , tie rod , travelall , truck , wheels , winch , windshield
