Seeing no other takers, here's what I'd do considering that the rear x-member in a SII is a known weak spot:
Scrub the remains of the stock x-member. You'll need to support the rear of the tub since you're losing mounts(temporarily) in the process. Then, 2x4 steel tube across the inside of the frame rails, flush with the end of the rails. .188" wall would be fine, .250 might be easier to find as a rem. Then, a hunk of 3x5x.188(or .250, but you may have to shave your body cushions a bit) angle, with the flange facing forward. Bevel cut the ends, drill for the body mounts, and skip weld the bottom to your 2x4. With .188 stock, that presents a bumper mounting face that's 3/8" thick, which should be plenty beefy. <edit>Be sure to weld the top of the angle as well, I just neglected to mention it on the first pass. If your upside-down-in-a-corner welding skills are pretty good, I'd burn a bead on the inside of the flange along the top edge of the frame rail. Last edited by Jim Grammer; 09-17-2007 at 09:34 AM. |
Jim's plan is pretty darn good. Nails it quite well.
If thats more work than your willing to do right now, you can beat the crossmember back into shape and weld up the cracks. Straiten the body mounts and reinforce the body mounts by welding a support on the back side of them (which would really be the front, facing the front of the truck). A complete new crossmember would sure be the stronger. |
| 2x4 , body , doors , frame , front , pictures , scout , top , truck |
