Old 05-04-2007, 03:18 PM
Harl's Avatar
Harl Harl is offline
Default T19 question
I'm looking for a T19, non-Scout version. I'm wondering what the differences between the tranny in a pickup, f'rinstnace, and the one in a Scout. The pickup has a tail housing and a yoke bolted to the output shaft. The Scout version bolts to the transfer case and the output shaft has a gear on it that feeds the tcase? Are the cases the same? So if I got a Scout tranny and put the different style output shaft, etc., in it, the tailhousing would bolt up? The reason I ask is I'd ultimately put a Gear Vendors O'Drive on it at some point and they don't make an integral kit for the older T98 tranny.
TIA
Harl
Old 05-04-2007, 08:42 PM
WRENCH MAN's Avatar
Default Re: T19 question
The cases are not exactly the same, the 4x4 case is drilled and taped for the adapter.
68 Rambler American
72 1210 4x4
77 ScoutII
97 JEEP TJ
99 Yamaha YFS 200 (248)
Old 05-05-2007, 12:48 AM
Mechanos Mechanos is offline
Scout II (married) T-19 case is drilled for the t-case adapter and has a 6 spline mainshaft.
Pickup (divorced) T-19 is drilled for the bearing retainer and has a 10 spline mainshaft, and has a couple other holes tapped in bosses on the side for the divorced t-case shifter linkage.
That's about it.
aka TORC
'80 Scout II
Old 05-05-2007, 06:20 AM
Harl's Avatar
Thanks guys. The output shafts are different, but I guess I'm still not clear on whether the case itself is essentially the same. Would a transfer case adapter bolt to a pickup case, even if you had to tap some holes, or are the cases completely different.
Old 05-05-2007, 08:32 AM
WRENCH MAN's Avatar
Yes, the "divorced" case can be modified to accept the adapter.
68 Rambler American
72 1210 4x4
77 ScoutII
97 JEEP TJ
Old 05-05-2007, 04:44 PM
Harl's Avatar
Thanks....
4x4 , adapter , case , gear , pickup , scout , scout ii , tranny , vendors
