Old 03-01-2007, 09:34 PM
bullscout bullscout is offline
Default dana 44?
I have 2 79 scouts both with 345 and 727 auto how can I tell if they have a dana 20 or 44 or could they be something else, I think they are both all stock
(I am going to part one out and may have some parts available in northern MI if anyone is interested)
Old 03-01-2007, 09:39 PM
Eli D. Eli D. is offline
Default Re: dana 44?
taken from the FAQ
Identifying Scout II Front Ends -- Dana 30 vs. Dana 44
As a rule, 1971 - 1973 Scout IIs will have the drum-brake Dana 30, and 1975 - 1980 Scout IIs will have the disc-braked Dana 44. Most of the confusion comes in the 1974 model year, when the conversion to disc brakes occurred, as well as the transition to the Dana 44. A 1974 Scout II could have left the factory with any of the following:
1) Drum Brakes on a Dana 30
2) Disc Brakes on a Dana 30
3) Disc Brakes on a Dana 44
Hence, the presence of drum brakes is a definite clue that you have a Dana 30. Disc brakes alone, however, are not sufficient proof of a Dana 44.
The Dana 44 diff cover is distinctly asymmetrical when viewed from the front. It is significantly wider (taller) on the passenger side. The Dana 30 diff cover is more "square-ish" and more symmetrical.
Further, the passenger-side front leaf spring is mounted to the axle tube with two identical U-bolts on a Dana 30. The same spring is mounted to the "shoulder" of the differential housing on a Dana 44, forcing the use of an inboard U-bolt that is both wider and longer than the outboard U-bolt.
unknown user
The web site
Image by Eldon McFarling
Eli D.
1965 Scout 800 196/4 sp./ twin stick D-20
1971 Scout II 304/4 sp. Rust Free
Old 03-01-2007, 09:41 PM
one has disk in front and drum in rear and not sure about the other one, both are 79
Old 03-01-2007, 10:12 PM
Mark Ashford's Avatar
Moderator.. or something
well, since the Dana 20 is a transfercase and a Dana 44 is an axle....
If they are truly bone stock, and provided no original owner special ordered something REALLY weird...
They should both be D44's front and rear, with discs in the front and Dana 20 transfercases.
Old 03-02-2007, 09:15 AM
I assumed he meant dana 30
Old 03-02-2007, 09:25 AM
DAGATOR16 DAGATOR16 is offline
Here ya go.
Clay
1974 SCOUT II, 345 AUTO
1980 SCOUT II, 304 AUTO
Old 03-02-2007, 04:31 PM
thanks they are 44's
Old 03-02-2007, 04:35 PM
they probably are, they SHOULD be if they are stock
1975 , 1980 , 345 , axle , brake , brakes , conversion , dana 44 , diff , differential , disc , front , part , parts , scout , scout ii
