Old 12-15-2006, 02:30 PM
Shiner-Bock-Beer's Avatar
Shiner-Bock-Beer Shiner-Bock-Beer is offline
Default '62 Scout 80 - What were the front end option
Trying to help someone determine what front end they may have on a 1962 Scout 80. It isn't local so it is hard to get a look at it. The mechanic that has it says it needs a new front differential. The line ticket, where it can be read, says 4.27 gear ratio and "FA-14 front driven axle." What could be on this vehicle as standard?
Darrell
Darrell
Hungry in DFW? Twisted Root Burger Company or Cowboy Chow
"Bob the Scout" - 1973 Scout, V8, 345, 102K miles, Pertronix, MSD Ignition, BHC mod (Unfortunately,) D30/44, D20 TC, rust all over.
Old 12-15-2006, 02:46 PM
Scott L Scott L is online now
Default Re: '62 Scout 80 - What were the front end option
Dana 27 axles, front and rear.
1966 Scout 800 - purchased 1995
1972 Scout II - purchased 2005
_ _ _ _ _ _ _ - purchase in 2015?
Old 12-15-2006, 02:48 PM
Jim Grammer's Avatar
Editor at large
Why, an FA-14 of course
http://www.binderplanet.com/techlib/lineset_codes.htm
Old 12-15-2006, 02:54 PM
Lava's Avatar
Lava Lava is offline
your mechanic doesn't know???
why did he say the front differential needed to be replaced?
Is it the ring, pinion, carrier, axles, housing, etc????
the seals and bearings done by a competent shop specializing in setting up axles should do it fairly cheaply and on hte fly with the parts they have on hand.
costs lots from the pikers, the real guys take less than an hour and about <100 bucks for parts
for new differential pinion and carrier bearings, set-up, and reseal.
Then there's the outers...
1600Charlie 1963 model 80 stock everything o/d factory soft top-a few homespun mods
Old 12-15-2006, 04:00 PM
I haven't talked to the mechanic at length. He just said it was seized up and needed to be replaced. So, the going consensus sounds like he should have the Scout towed to a better, more competent axle shop and they can handle it.
Darrell
100 , axle , axles , bearings , binderplanet , dana 27 , differential , front , front end , gear , parts , scout , scout 80
