AZIHR 2015
Old 11-24-2006, 10:25 AM
Cody K Cody K is offline
Default 1970 International Scout engine identification
a freind of mine has a 1970 International scout we honestly do not know what motor is in it, we suspect it is a 1971 304ci motor but thats just what we suspect is there any easy way for us to identify if it is in fact a 304 international? and if it turns out that it is a 304 what is its oil capacity? the engine in it now has a distributor up front with a motorcraft 2 barrel carb....any ideas? thnx
Old 11-24-2006, 10:36 AM
Greg R's Avatar
Greg R Greg R is offline
Default Re: 1970 International Scout engine identification
Here's a link in the FAQ's:
http://www.binderplanet.com/forums/f...l&titlesonly=0
The FAQ's have lots of info, sometimes searches are difficult till you get the hang of what strings/words to use. It is a good place to start. Oil capacity is 6 quarts. Motorcraft carbs are not too uncommon, I've got one on my 345.
69 800
266 V8/4spd & D18TC/OD
4.27 D30/ D44
'56 S110 240 I6/4spd
'71 1210 345 V8/4spd 2WD
'67 Travelall BG246/4spd 2WD
Old 11-24-2006, 10:37 AM
thescoutman67 thescoutman67 is offline
If You look above your fuel pump there will be a flat smooth space right above it scrape off the grease and dirt and it wil say v-304 v-345 or v-392,all IH V8 distributors are in the front. and a motocraft carburetor is compatable with IH intake manifolds.
sincerely
Thomas Taylor
Old 11-24-2006, 10:40 AM
sincerely
Thomas Taylor
hey thnx man i'll take a look we really apriciate it
2 barrel , 345 , binderplanet , carb , carburetor , distributor , engine , faq , front , oil , scout , start
