Old 08-19-2006, 04:01 PM
Brandon A. Brandon A. is offline
Default Gas mileage tips!
Hello I was surfing the internet the other night as my parents informed me that they were going to try acetone in their gas tank for better mileage. Apparently there friends had tried it and it helped. While searching I came across some very informative websites. They claim to have ways to significantly increase your mileage. I am particularily interested in the (Fogger) product as I have read in the past that heating up the gas for better burning can improve mileage. I wouldn't mind trying one but I am stuck out on the road and will only get home once a year. Here are the websites the list of 13 things on the first site is where I would read first the (fogger) is listed at the bottom of the page.
* I am in no way affiliated with this product, just very curious!
1. http://www.lubedev.com/smartgas/ultra5.htm
2. http://www.lubedev.com/smartgas/fogger.htm
3. http://www.lubedev.com/smartgas/warm/install.htm
4. http://www.lubedev.com/smartgas/warm/photo.htm
Let me know what you guys think, or if anyone would like to see if these ideas work? THanks Brandon....
5. http://www.lubedev.com/smartgas/faq.htm
s pictured at the bottom.
Old 08-19-2006, 05:06 PM
Chris Joens Chris Joens is offline
Default Re: Gas mileage tips!
I am a mechanic at a Caterpillar dealer. One day a truckdriver came in saying his AC didn't work .I looked at it and he had put some long magnet on his fuel line that was supposed to do something for fuel milage .that made the fuel line heavier so it sagged down rubbing a hole through an AC line .
76 scout II
76 scout traveller
69 1300C
"It is far better to own 7 $100 cars than 1 $700 car."
Fred Eaglesmith
Old 08-19-2006, 06:01 PM
tomausherman's Avatar
tomausherman tomausherman is offline
Send a message via AIM to tomausherman
One of those says larger tires will give better mileage..what's up with that?
Old 08-19-2006, 06:17 PM
scouting II's's Avatar
scouting II's scouting II's is offline
Cool info. I suspect we will be seing more of these types of things as more and more people get tired of the bs going on with gas prices.
"Health is merely the slowest possible rate at which one can die."
Old 08-19-2006, 06:20 PM
scoutman800's Avatar
DIESEL!!! maybe like the 3.0L in the rangers they run in brazil. on soybean biodiesel too!
sons of liberty
Old 08-19-2006, 07:28 PM
Erik VanRenselaar's Avatar
Erik VanRenselaar Erik VanRenselaar is offline
Gallon for gallon, diesel has more BTUs than gasoline.
But with the price of fuel in Europe being high for decades, anything *special* that could provide better fuel economy would have come from there already...
Small (= lightweight/aerodynamic) 4-cylinder powered vehicles. That's how they minimize their fuel costs in Europe!
Seriously, a good way to achieve the best fuel economy from something like a Scout/Travelall/etc. is to drive at the posted speed limit on the highway and avoid rapid acceleration or braking.
'75 & '76 Scout IIs
Amateur radio operator, General Class - K6IHC
Work Smart, Not Hard...
Old 08-19-2006, 08:38 PM
Darel Darel is offline
If heating your fuel worked, then it's done by design. Do it any more and, oh, yeah, vapor lock!
Similarly, adding acetone costs more than the fuel it saves. Buy a bottle of acetone and add it to your tank. If you save one whole gallon of gas (which would be downright amazing) you still wouldn't have equalled the cost of the acetone you added.
The solution to saving gas is the same as saving water - put a brick in your toilet tank, put a brick under your gas pedal!
My '75 200 with a 345, 4-speed, untouched-since-1975 two-barrel Holley and almost 1,000 lbs. of tools and wire in the back 24/7 gets 13-15 mpg. My mother in law drives a 2004 F150 (completely unloaded, obviously) with a 4.6L V8 that has yet to break 9 mpg. In two years she has yet to pull her right foot off the floor. Short of keeping the car you have in good tune, or trading your vehicle in for a diesel, the only thing you can do to actually save money (read: not throwing tons of money at incremental mileage increases) is change your driving style.
Of course on vehicles as old as ours, keeping your vehicle in tune can be a full-time job...
Current:
'75 200 4x4, 345, T19 wide, D60/D44HD, driven every day
Former:
'67 800, 196/T18, Factory-correct frame-off resto
'77 Traveler, 345, T19 wide, D20, D44s, nothing stock
'64 Travelall 1100, 345/T98
'61 C100 pickup, BD241/T98
'77 Traveler, for parts
Old 08-19-2006, 08:52 PM
iheric's Avatar
iheric iheric is offline
I personally don't buy any add on's to aid mileage. I do believe in fresh spark plugs, air filter, and proper tire air pressure. Don't carry around anything you don't need, keep the a/c off, and drive with a light foot.
Old 08-19-2006, 10:09 PM
David Fulford's Avatar
David Fulford David Fulford is offline
It has the same effect as having taller gears, so this is true if you do a lot of sustained highway speed driving.
Larger diameter tires have a larger circumference, which means you cover more distance with each rotation.
There was someone on this board that actually did a test using acetone and didn't see any significant difference. Using the search function should find it pretty easily. He actually posted numbers.
'79 Scout II,SOA by D&C,Heavy D&C Z-link,304/727/D20,New Holley 2300 carb & electric choke,33x12.50's on 15x10's
Paint by Riley Customs, Martinsville, IN
CLICK HERE--History of my Scout.
Old 08-19-2006, 10:15 PM
iheric is on the right track. well tuned motor, the right carb and not going any faster than ya need to. people always assume my scout gets terrible mileage. it's actually better than my work trucks have been overall. and it will wheel the pants off of them!
sons of liberty
1975 , 345 , brake , carb , cylinder , diesel , distributor , efi , engine , fuel economy , gas pedal , holley , key , lock , number , oil , safety , scout , switch , timing , tires , transmission , travelall , water , winch
