Post #31 Rare glimpse of a 72 International Wagonmaster crewcab pickup unibody Post #36 Corporate 14 bolt information links (and #38) Post #50 78 GM ¾ ton Heavy Duty Dana 44 disc brake front axle install parts list Post #55 68 Travelall one-man body removal Post #56 Scored a T-35 5 speed trans - info starts here ================================================== ============== Time to start working on my 1968 Travelall 4x4 project that I towed home over three years ago. I will call it my “INTL 4X4” as that is what the personalized license plate now says. Here it is the day it arrived back in 2003: ![]() This poor Farm-Boy Travelall came with a make-shift lift using three spacers in the back totaling 8 inches and one 2.5 inch spacer ON THE FRONT AXLE The overall truck is virtually rust free, with only a few spots that will need attention in that regard.I originally bought it as a parts truck for my stable of three other Travelalls at the time. Now I only have a 1972 Travelall 4x4 with 392V8 and a rusty body. This 68 Travelall has a clean body, so… the natural thing to do is a body swap of the 68 body onto the 72 running 4x4 chassis, at least that’s the plan. I have always liked the 60’s Travelall round-body the best, but appreciate the newer axles with modern disc brakes and power steering. So far I have managed to pick up a Dana 44 Heavy Duty 8-lug disc brake front axle and a Corporate 14 bolt 8-lug rear that I have converted to disc brakes and installed a new Detroit Locker. In addition, I managed to steal a complete set of new take-off Hummer H2 wheels and tires that I’m sure some Flat-Lander pimped out with 22’s or something similar that will never see dirt in its lifetime .The Dana 44 front has been installed in the 72, but the steering is not finalized. The H2 wheels have a large offset that pulls the tires back in on the 2” wider Chebby axles. So far it looks like it will all clear okay. The Corporate 14 bolt is still in pieces ready for assembly. I’ll be running 411’s with 315/70R17 BFG T/A KO’s (~34.5”). Both trucks have 4-speeds, but I do have a good 1975 automatic sitting in the chicken coup. I think my choice would be a 5-speed T-35 (7.17 down to 1.00, no OD), but do not have one of those yet. Here is the 72 with front fenders off, D44 in and H2 wheels on: ![]() That is about it for the first post on this long-term project. Any and all recommendations are welcome, as this project is currently in its infancy. I am sure I will have many questions as time goes on.
Last edited by LeeC; 12-10-2009 at 08:36 PM. Reason: Removing personal photos from the net - Vanna's better looking anyway |
Nice to see another 68 gettin' the treatment it deserves.
Good luck on your project, Lee! -John
Iam also in the process of building my second 68 travelall,got rid of the first.This one started as a 1000,I pulled the body myself and put an 1100 4x4 frame under it.Used floor jacks,jack stands and long 4x4's.But if your frame is not rotted why change it.Its almost the same as the newer frames just with the cab mounts in diffrent places.Its much easier just putting your axles ,engine and tranny on the 68 frame.
Do you have a thread started for your project? If so, post it here. I'll add it to my subscriptions. The frame on the 68 really needs to be striped and painted. The frame on the 72 is cleaner, plus has a nice Reese trailer hitch welded in some spots. The 72 frame is longer in the back. I'm hoping I don't have to cut any off. I think it just fills the space between the end of the 68 frame and the body (?). I want to do a "frame up" clean-up and paint, so either way I'd prefer to pull the body off. If one had started life as a 3/4 or 1 ton, then I'd use that one, but... sadly both are 1/2 tons How are the cab mounts different? I thought the only change was the thickness of the center front clip mount. Guess not? |
One day we will have to get the 68's together for a adventure trip and photo op.
![]() -John
Thanks Jim. Should I pull the front body mounts off the 68 frame and put them on the 72 frame? Or is it easiest to just remove the 72's and move them forward?
Even though it isnt a Travelall, or a 4x4, yall are 2K plus miles away, and its kinda low for anything but a street adventure trip. Seriously though. Im looking forward to see your project come together, Lee. Mike
| 1200 , 1968 , 4x4 , adapter , aftermarket , axle , brake , brakes , case , cooler , disc , disc brake , door , efi , frame , front , number , part , parts , project , pulling , start , towing , travelall , truck |
