I recently purchased the foor door version of this truck, and I've been going back and forth with what to do with it... I think I figured it out! Whadayathink? Now, if only building it were as easy as photoshopping it... Ok, so... in theory... how would you do it? Assume that you already have the Travelette. Would you get a Travelall cab and rear doors, split the Travelette cab, and graft the middle of the T-all cab into the middle of the T-ette? Better to use two T-ette cabs? Yeah, I'm just dreaming, but if you're gonna dream... dream big!
Fat Boy 1968 1200C Travelette 4x4Bandit: What do you think they do for excitement in this town? Snowman: Probably sit around and watch the cars rust. |
You're crazy!
I just put together an extended cab Terra, but I didn't have to mess with any extra doors. I had thought about taking the middle out of a 60's Travelall and making a two door out of it, about the size of a full size blazer.
I think the easiest would be a travelall front with the rear half of the travelette cab. Would need to reinforce the cab and frame...
You could always just buy an airport limo and keep it as travelall. ![]() That is a very interesting idea though, a lot of work though...
Ryan '78 SII et al |
Ryan is absolutely right on this... Front piece of a travelall and the rear piece of a travelette. I'm not sure about reinforcing the cab, they're pretty stout as they are, and if you're a good welder it shouldn't be a problem. Might need another cab to frame mount though...
The frame is another story though. I dunno if the 4x4 frame is boxed already, or if it's a U-beam design. If it is a U-beam, I'd drop in a center piece from the donor, and then box it. Don't forget to cross measure the frame before welding.... This looks like a project I'd like to do.... Paul
Paul Wargenstahm Computer & Electronics Engineer 1967 IH 1000B with GM 6.2D, TH700R4, running WVO and BioDiesel. 1964 IH C1200 4x4. The new one... ![]() Build-up pics at: Paul's IH Pages (updated Sept 7, 2012) |
There are some changes to the roof line, at least in the D series - there's a tell-tale method of determining if a WagonMaster is a WM, or a backyard modified Travelall based on the roof, IIRC. In any case, I'd cut the B and C pillars out of a Travelall, cut the Travelette at the B, and graft the T'all parts inbetween. Watch out for any "kick-up" of the frame, so you'd probably have to slice and fishplate the frame to stretch it appropriately. Was it originally a 3/4T, or did you just swap the axles? I don't have the frame specs handy, but the 3/4T D-series had a heavier frame, so did the Travelettes, with the 1T and 166" WB T'ette having the heaviest frames. Along those lines, you might want to plate the entire lenght of frame from the "kick-up" to the engine mounts to help account for the extra span. Did the rear seats in the 60s T'all fold down? I'd make an attempt to use at least one Travelall seat in there, so you can fold it down more or less flat to make a deck and/or bed sized area inside (if you can get both seats to fold flat, that'd be great!)
We Race Farm Equipment M4x4A #576 KE7VUX |
LOL !... thats great
but ya gotta ask yerself one question ????? WHY ? if youve stepped away from the beer and you still think its a good ideer DO IT ! DO IT ! DO IT !
"A BUSHEL OF CORN FOR A BARREL OF OIL !" ABOMINATION / obama-nation ... not just a random synonym |
If you cut the front off a travelall and graft the rear of a travelette, you've got one splice of the two bodies. If you are inserting a travelall section into a travelette cab, you've got two splices. Plus, if the cab roofs are different, it seems it'd be easier to "blend" them at one point then two (especially going back and forth).
Paul
You could then either shorten the Travelall roof, or section in the Travelette cab rear roof area. I wasn't thinking. I was thinking "If I have a Travelette cab, how do I stretch it?" not.. "how would I go about building a 6-door T'ette if I had a Travelall and a Travelette handy" ![]() Once you've come to the conclusion you NEED a Travelall and a Travelette to do it, I think you're right on the money with starting with a Travelall and replacing the rear half. Did Stageway build stretched C-series? Start with a Stageway Airporter and then slap the back of ANY single or double cab in at the point you want it. ![]() While we're at it, why stop at a 6-door T'ette cab? Use the very rear section of the Travelall body to build an extended-cab, too. There's a picture of a D-series single+excab in the Crismon book. A Travelall body was shortened to make the cab. The "extended" part was roughly made by taking the top rear portion of the T'all glass, and cutting straight down, keeping the rear "triangle" of glass in a D-series Travelall, and bringing that forward to the back of the cab.
| 345 , 4x4 , axles , body , case , conversion , d series , door , doors , engine , frame , front , full size , glass , master , part , parts , project , rust , shorten , start , terra , travelall , travelette , truck |
