Old 06-08-2006, 02:53 PM
Dave Clifton's Avatar
Dave Clifton Dave Clifton is offline
Default Injection Forum Donation: GM/IH EFI Wiring Diagram
Payback for all the help from Bill and everyone else...
This Wiring Diagram is exactly how I wired my Scout for the GM EFI System. Fired up first time. Easy to trace colors (per the GM harness) and connections from the diagram to the Scout. If you go carefully, wire by wire, double checking and THEN perform the Key "ON" voltage checks...It WILL START 1st time if all sensors, relays, TBI Injectors, and ECM are fully functional (not fried beforehand).
I used the Duraspark Distributor Conversion, 1227747 ECM, 454 BB TBI (note the crossed wires), no EGR, no Knock Sensor, with VSS, with A/C, with Park/Neutral wire. I even listed the IH wire/circuit numbers I used to tie in to the Scout.
Happy Scouting!
Dave Clifton
'77 Original Owner (Yes, that's 36 years!!)
V304 250,000 miles and retired.
V392 35,000 miles and counting...
EFI, 727 w/ D300, RS/SUA/Electrac Front, SOA Detroit Rear, Hydroboost, 33x16's
Old 06-08-2006, 03:19 PM
Default Re: Injection Forum Donation: GM/IH EFI Wiring Diagram
Thanks Dave, it looks awesome.
One note to others(well maybe one)
It looks perfect printed. It just doesn't do it justice looking at it on screen.
Make sure to read the notes!!
Here's a small jpg example.
Print the pdf file for use at home!!
Old 06-10-2006, 04:04 PM
DirtySideDown DirtySideDown is offline
Nice Work ... Printed it out on 8.5 X 14, legal paper, looks "killer", saved it to a file.
Boy that's a Sloooowww opener on a dial connection...
Still gathering parts for my conversion....decided I'm going to install EFI on the 409, just for the hellofit..may still put the 4.3 in at a later dated...
Old 06-12-2006, 12:16 PM
EagleMark EagleMark is offline
Banned
Wow! Nice job.
Old 06-12-2006, 04:55 PM
Jensers Jensers is offline
Send a message via MSN to Jensers
Have been using it during my build - Thanks for posting!
Old 06-13-2006, 01:02 PM
Brian Rognon Brian Rognon is offline
Right click, save as...
Thank you for sharing the info!!!
Brian
Brian
'73 Travelette 4x4 (Getting better)
'74 SII (30 beer camo paint job)
'75 Traveller (Yard decoration)
Old 05-07-2009, 07:34 PM
gte901m gte901m is offline
I'm assuming you made this in AutoCAD. Any chance you could post up the dwg file? I want to modify it to include a knock sensor.
I'll be happy to post the modified version in pdf format for anyone else who needs it.
Old 05-21-2009, 08:24 AM
Darn if I can find the native .dwg file. All I can locate are printed copies and PDFs. All my CAD work now is in SolidWorks. I'll need to search some backup drives/DVDs.
Recently I built a new PC and never reloaded ACAD. So never missed it until now. I'll keep searching.
Dave Clifton
binderplanet , build , click , colors , conversion , distributor , ecm , efi , egr , key , parts , scout , start , tbi , wiring
