![]() I put this together to keep in my glove box, tool box, junk yard kit, etc. It was handy to check things off as I found them - or to reference at the parts store when I needed a part and the guy behind the counter began to get the deer in the headlights look. It may be a waste to most of you -- but hopefully it will be helpful to somebody. It is a PDF - so it should work not matter what you do... Last edited by Chrispucci; 11-18-2006 at 09:19 PM. |
If you want, I will down load and add some more parts to it, then include it in the FAQ.
We can keep it as part of the parts required "shopping list"
I consider it an 'open source' document. Thanks. |
Here is the excel version (pre PDF'd) if you want to edit/modify...
added fuel repair lines from atlantascout Last edited by Bill usn-1; 11-30-2006 at 09:20 AM. |
If someone wants to update the spreadsheet and/or PDF, the Bosch part number for the 3 wire heated O2 sensor is 13942. I found it using the good old search function, but I figured I'd comment here to save others the time.
Thanks for making & posting the lists, Chris, and for posting the link in the FAQ, Bill.
Alan St. John, aka Gloves Moderator, ODBA Website & Forums '67 Scout 800 "Kemosabe 2.0" '73 Scout II w/Camper Top "Cammy" |
| faq , headlights , number , part , parts , tbi |
