Old 02-05-2003, 01:06 PM
lilbluescout63 lilbluescout63 is offline
Send a message via Yahoo to lilbluescout63
Default 4 cyl and 8 cyl distrid ? difrences
i am assuming a 4 cyl and 8 cyl dist are difrent in that a 4 cyl only has 4 lobed and a 8 cyl has 8 lobes is this corect any 1?
lil blue 72 scout 304 / auto
79 dash & rear seat fresh 1/2in shag 1/4 in padding
Old 02-05-2003, 01:22 PM
Mechanos Mechanos is offline
Default Re: 4 cyl and 8 cyl distrid ? difrences
Basically, yes, that is correct. Well, other than the cap only having 4 terminals instead of 8
aka TORC
'80 Scout II
Old 02-05-2003, 01:28 PM
Default ok thanks
thats what i thought and yes i know u cant use a 4 cyl dis cap on a 8 cyl lol but im also assuming you can put a 8 cyl lobe in a 4 cyl housing via 154 196 to a 304 as a 152 196 is bacicly a 304 in 1/2
Old 02-05-2003, 01:57 PM
mrutledge mrutledge is offline
Default
I'm not certain about the 152, but the 196 is the right half of a 392.
Old 02-05-2003, 02:10 PM
Default my books show
the 152 is the 1/2 ove a 304 down to all the specks as the 196 is the 1/2 ove the other block the 152 and 196 are verry simulas with verry few difrences in my books thanks
Old 02-06-2003, 05:37 AM
George Womack's Avatar
Default
You can make a 4-cyl distributor into a V8 dist. and vice versa by swapping out the points cam and dist. cap. This is assuming you're swapping between two distributors of the same make. The Delco and Holley distributors are very different in construction and their parts won't interchange.
Old 02-06-2003, 09:41 AM
Jeff Eggemeyer Jeff Eggemeyer is offline
Default
The cam lobe in a holley points disty is a part of the the upper shaft. Only way to remove it is to grind it off. BTDT.
79 SII/392 (0.030 over) Hamilton Injected/727/D300/Full size axles/36" Swampers/Lockers/OBA/38 gal fuel tank
KC9AFO
Rosebud Metalworks
Can't buy it?? Make it!!
"Can't fix stupid, Stupid is forever"......Ron White
Old 02-06-2003, 06:59 PM
Default
The cam is attached to the shaft, but is easily removed from the shaft after removing a small retaining clip.
Old 02-06-2003, 10:03 PM
Default
George,
Yes, there is a small clip under the felt that allows you to remove the upper shaft. The one that actually contacts the centrifugal weights. However, the one I have, after removing the felt and clip, the upper shaft came right off. As for removing the cam lobe for the points, there was no retaining clip and there was no "just tapping it off". I had to grind mine down till it was round again. If yours "tapped right off" you had it easy, mine didn't tap off, no way no how.
KC9AFO
Rosebud Metalworks
Old 02-07-2003, 03:36 PM
Default
Jeff-
We are talking about the same thing. What you are calling the "upper shaft", I am calling the points cam. IH calls this part CAM, BREAKER. This is the part I am talking about swapping. You are right in that the "cam" is part of the "upper shaft" and can't be removed. But this part can be swapped with another distributor to change from a 4-cyl to an 8-cyl and vice versa.
cam , cap , distributor , holley , part , parts
