For Non-Fuel Injection Quote:
Part Number: EL107 Vehicle: 1979 FORD F-150 PICKUP Engine: V8 5.8 Liter 2BBL Module; OE Style; 351M Engine; 351W Engine; Except High Altitude Distributor # D6AE-12A199-A1A/A1C/A2A/A2B/A2C; D8VE-12A199-A1B/A1C/A1L/A2B/A2C; E8PF-12A199-AA/AB Our Price: $19.48 You can grab the wires and the ignition box from the junk yard when you get the base plate. I normally pay $10-$15 for everything. If you look around, sometimes you find some near new replacements parts hiding in there! The later TFI coil is another option while you are grabbing parts. It's an epoxy core coil so there is no oil. Like the GM coil. Used by Jeep guys with DS. Part Number: FF179 Vehicle: 1988 FORD BRONCO Engine: V8 5.8 Liter FI Ignition Coil: Windsor Our Price: $21.99 Here is the wiring. (view in normal mode not dark) ![]() EDIT: white wire should go to S terminal vice I terminal. Duraspark troubleshooting guide If you want MSD with the DS pick up!!! Now how about something easier. Here is the DS distributor running a GM 4 wire ignition module. Now you get modern electronics (same as the $$$ HEI Distr has) that are available in every parts store and junk yard. Ignition Module PN- EL102 CONVERSION PERFORMED ON A JEEP WITH DURASPARK. Here it is installed by John H. ![]() HEI trouble shooting ----------------------------------------------------------------------------------------------- For Fuel Injection here is the wiring diagram to connect your DS conversion to the 8 pin EST. Thanks to Brendan for the diagram. HEI trouble shooting Note: When setting the timing for the first time you must ensure the wiring is correct on the ignition module. The 2 wires from the pickup in the distr must be connected to the proper terminal, P and N on the module. To verify they are correct: A. Set engine to TDC compression stroke. For IH use #8 for V8s and #1 for 4 cyls. For all other makes use the correct plug. B. Remove the cap and verify the rotor phasing is correct IAW the distr conversion thread. Rotor should be just past center of the cap terminal in the direction of rotation(clockwise for IH) and the reluctor should be lined up. C. Connect timing light and disconnect the timing bypass connector if EFI. D. Crank engine to check timing. If the wires are connected properly then the timing will be within 5* of 0*. Just set timing to 0 and your good. If the timing is 20-30* away then swap the P and N wires and check again. Quote:
Bill USN-1 ![]() Click a link below that meets your needs! Either DIY or let me help. COMMITED TO HELPING PEOPLE "PROPERLY" INSTALL EFI Learn to do it right. May be the answer to all your fuel injection needs! WANTED-Holley Distributor Last edited by Bill usn-1; 07-14-2011 at 10:24 AM. |
Still working out the details... Thanks. |
When you do the conversion for the FI you just hook the purple wire to the P and the orn wire to the N terminal of the 8 pin ESTign module that you mount on a plate next to the coil. The black wire goes to gnd. I'll Add the EFI diagram and connections. Check back in a few!!!
Bill, are the Duraspark distributors common across the entire Ford V8 line? Will one from a 302 have the correct baseplate?
Dave
Dave Clifton '77 Original Owner (Yes, that's 36 years!!) V304 250,000 miles and retired. V392 35,000 miles and counting... EFI, 727 w/ D300, RS/SUA/Electrac Front, SOA Detroit Rear, Hydroboost, 33x16's |
As long as it is a duraspark and not a TFI, you are fine.
The TFI will have the ignition module mounted on the side of the distr. I have used 302, 351, and 460 DS distr parts!!
What is the correct value for the ballast resistor?
3.2 ohm (acording to the counter clown) or the more common 1.2 ohm? Maybe I missed it here somewhere...
It takes a lot of balls to build bearings Charter member, Night Crawlers Off Road Club. |
What system are you running? What coil are you running? You only need the ballast resistor if you are still using a coil that ran a ballast resistor. I ran the later epoxy coils and no ballast resistor. If you converted from a points system and kept the original coil then you will need to keep the ballast resistor. There may be more than one resistance value based on the application.
sorry, running the DS system.
Wired as pictured in the first wiring diagram in this thread. Using the parts called out here also. Smoked one module already.
Here is some good troubleshooting and diagrams.
It appears the 76 system used a ballast resistor and the 78 and up did not. DS trouble shooting It also appears there is a wiring error on the second diagram with red and white going to the Run circuit. It will probably work but may not be the best way to wire it.
well, the module listed here is after 76, so I'm guessing the correct answer is:
No resistor???
| 2bbl , bar , binderplanet , body , click , coil , conversion , distributor , efi , electrical , engine , frame , ignition , ignition box , number , part , parts , pickup , plug , power , scout , starter , timing , top , wiring |
