To keep stickys to a minimum, I will try to keep the most important threads linked from here.
First, all information is free but this web site isn't. So as you sift thru all I have posted here, if you feel it has helped or saved you some time or money...please consider becoming a member. This will also allow you to post logged data for us to help you perfect the installation. Before you start here is a little introduction Video for your enjoyment. The most important question is: What system do I want? GM Based system. First- What parts do I need? What Throttle Body adapter do I need? Then we need to be able to hook all these parts up so: What wires do I need to use for the 1227747? How about the later16196395/16197427 And then.... what distributor can I use? (for FI and carbs) Duraspark conversion using a Holley distr Duraspark conversion option 2 Mopar conversion using the Holley Distr GM/IH Hybrid DUI/HEI/Stock Duraspark conversion using a Prestolite dist Once the initial installation is done then you need to perform these initial setup procedures. I built the Distributor, so what do I hook it to? (Ignition upgrades for FI and carbs) Ignition Systems FUEL SYSTEMS In Tank Pumps Dual Tanks How about Dual Fuel options 304 Dual fuel conversion MISC Can you walk me through a fuel injection conversion step by step? Thread in progress!! What about Fuel Injection on a 4 cyl? Another 4 cyl TBIOnly this one has DIS- distributorless ignition How do I remove Injectors or make my Fuel Pressure Regulator adjustable? What VSS can I use? TUNING AND PROGRAMMING CHIPS How do I get the data out of the computer and then change it? Basic chip adjustments How do I install the Moates EEPROM adapter? How to convert from the 2732 EPROM to a 27SF512 EEPROM LINKS Where else can I go to get more information and reference material? What if I still have questions because you didn't do a very good job of explaining it? Take a look at this Video, it may help!
Bill USN-1 ![]() HAMILTON FUEL INJECTION May be the answer to all your fuel injection needs! Last edited by Bill usn-1; 08-24-2010 at 09:48 AM. |
Needs moved up!
Bill USN-1 ![]() HAMILTON FUEL INJECTION May be the answer to all your fuel injection needs! |
| 345 , 800 , adapter , binderplanet , body , conversion , distributor , faq , holley , ignition , parts , start , tbi , throttle |
