Old 12-19-2005, 12:21 AM
Alan F Alan F is offline
Default 3/4 ton Chevy brakes on Scout Dana 44
Can I put 3/4 ton Chevy brakes on a Scout Dana 44? I figure use the Dana 30 knuckle and mount the Chevy 3/4 stuff. How much wider would the stock axle be with the Chevy brakes? I don't know if I could use the stock Chevy stub (short) axle shafts or not. I guess I have my eye on the 63" WMS daully 14bolt axle and I figure if I can get a 3/4 ton front with a similar WMS measurement that would be good.
'73 Scout, 345, 4sp, Dana 30/44, 4.10/4.10, broken/Detroit, 4" lift, 33" Muds
Old 12-19-2005, 08:11 AM
Chrispucci's Avatar
Chrispucci Chrispucci is offline
Default Re: 3/4 ton Chevy brakes on Scout Dana 44
The 1st Dana 44 I can think of with a WMS-WMS of around 63" is a Jeep Wagoneer Wide Track axle. They come 6 lug (I think....). A standard Chevy 3/4 ton front D44 will be something close to 67".
As for putting the 8 lug stuff on a Scout II dana 44 - I'd swap the entire knuckle and everything on the Scout axle. Use the Scout II inner axle shaft with the Chevy outer - it should net you 1 1/2" - 2" per side of increase width.
It is all interchangable and there are many - many options that work. But to get 8 lug with some steering option (flat top knuckles) I'd just go all Chevy from the knuckles out.
Chris
Chris Pucci
Dana 44 cut and turn details
Old 12-19-2005, 08:17 AM
scotty85 scotty85 is offline
ive not done that,but it should work. the only prollem i forsee is if the oirentation of the 6 bolt spindle pattern puts caliper bracket at an angle that causes interferance with the caliper and knuckle. if that occurs,you should easily be able to grid some on the caliper and/or knuckle to make it work.
other than that-
-it will be about an inch wider per side with the 8 lug hubs
-you will HAVE to use the chevy stubs to match the chevy internal mount hub. you stock 44 scout stubs will now be of little use to you
further swap questions?
85 grand wagoneer(whats left of it)
77 traveler truggy(345/t19/10 bolt/14 bolt/38" 'hawgs)
NightCrawlers 4wd family
Scout Buildup Pics
Old 12-19-2005, 08:32 AM
Mark Ashford's Avatar
Moderator.. or something
Actually it adds about 1.5" per side.
Net result.. a 63" wide axle
Unless you have a good reason to do so (i.e. retain stock steering) I'd use the GM knuckles as well, then you know everything works, but I don't see why SII D30 knuckles wouldn't work, just never tried it.
As other have said above, you will need to use everything from the knuckles out GM, Spindle, Hub, caliper brackets, stub shaft ect....
SOA or SUA??
Old 12-19-2005, 07:02 PM
Thanks for the answers. I didn't even think about the Wagoneer axle. This would be SOA on a Traveler. I have a Scout Dana 44 with nothing but the housing, a spool, and 4.10 gears (installed). I am just checking out my options. I have read up on the full width axle swap with Hummer wheels. I am trying to decide between a 1/2 ton SUA Scout and a 3/4 ton SOA Traveler.
Would I need a hi-steer if I keep the Chevy steering knuckles?
Old 12-21-2005, 02:18 PM
Damian Grihalva's Avatar
Damian Grihalva Damian Grihalva is offline
You can use everything including the knuckle ~ which is what I recommend and then go with HySteer.
Damian (a.k.a. Snoopy)
www.dandcextreme.com
Evolution Build
Rusty's Buildup
More of my Builds
Old 12-21-2005, 02:42 PM
Afireinside2285 Afireinside2285 is offline
Marks right you should end up right at 63"(Scout axles 8 lug outters) which as you noted is the same as a c&c 14 bolt a good combo.
You could either go hy-steer or Z link to tie rod but if your going through the work I would just do hy-steer or crossover and buy the other arm later.
Good luck
Old 12-21-2005, 02:51 PM
exactly, the chevy knuckles don't have a place for the draglink on the passener side (just one hole) ~ so doing a X-over steering will be the best thing ~ and most likely the cheapest since you don't have to buy the knuckles and such, you're looking at $120 tops plus machineing, plus draglink
Evolution Build
Rusty's Buildup
More of my Builds
Old 12-21-2005, 02:57 PM
scoutman800's Avatar
this thread interests me as i keep seeing upgrades for chevy/ford brake systems. stainless 2 piston calipers and big slotted rotors. sure should bring it down fast and hard. like i need another project now............
sons of liberty
Old 12-29-2005, 08:32 PM
Chrispucci's Avatar
FYI - 8 lug Chevy 3/4 full width axles are 69 1/2" Wide as opposed to the earlier quoted 67" wide.... (67" is 6 lug 1/2 ton Chevy).
Thank you as you were....
Chris Pucci
axle , axles , brake , brakes , caliper , dana 44 , front , piston , project , scout , scout ii , soa , steering , sua , tie rod , top , wheels
