Old 12-05-2005, 10:34 PM
bluescout's Avatar
bluescout bluescout is offline
Send a message via AIM to bluescout
Default Source for a cheap heater core?
I think I might swap in a new heater core in my quest to get decent heat out of my diesel. Anyone know a cheap source? Napa is $50, as is Autozone.
1979 Scout II full of fiberglass and diesel fuel
Old 12-06-2005, 07:02 AM
Default Re: Source for a cheap heater core?
i don't beleive you're gonna find 1 any cheaper than that!?jeff
Old 12-06-2005, 09:31 AM
MagicalMichael MagicalMichael is offline
Bluescout,
before you swap out your heater core you may wish to check a few other things out. I have a 78 with the diesel and get plenty of heat and I am am way farther north than you are. A heater core usually can be cleaned at a raditor shop. You want to make sure that your water flow is not restricted by your valve. A simple test is check the hoses going in and out becareful they can get hot real quick.
Mike
Old 12-06-2005, 10:18 AM
bluescout's Avatar
I've been through the system with new hoses all around and even eyeballed the hole in the valve just to make sure it can flow. I've tried to flush the heater core and it flows plenty of water. I have the right style thermostat with the little plate on the bottom even. I've replaced the heater box because of rust and made sure the core was good and sealed into it. My last trick is going to my friend's shop to check the inlet/outlet with an infrared temp probe. The recent sold snap here got me thinking about it again.
Old 12-06-2005, 10:37 AM
CareyWeber's Avatar
Diesel Herder / Moderator
Have you verified that the air duct are open and are not plugged with leaves and stuff.
If you have good coolant flow then you shout have heat.
I'd bet the duct on both sides of the heater needs cleaning I know it helped mine.
Carey
  • Carey
Old 12-06-2005, 11:08 AM
binderbart's Avatar
binderbart binderbart is online now
one thing you could do is warm the scout up real good, then grab the heater core hoses one at a time. it they are good and hot and feel about the same I would say your heater core is working.
Why farm half when you can FARMALL!
73 scout II- "Agnus"
76 terra
77 trail scout (custom body)
79 GMC 3/4 ton (Dad's truck) "The General"
02 H.D. Sportster 883R
Old 12-06-2005, 11:12 AM
John Donnelly's Avatar
Administrator
What temp is your thermostat?
-John
Old 12-06-2005, 12:16 PM
bluescout's Avatar
My thermostat is a Napa 180. I get plenty of air out of the system, it's just warm. The only two things I can think is there's a lack of coolant flow or the core is partially plugged.
Old 12-06-2005, 02:34 PM
Dan Powlus da duke's Avatar
Dan Powlus da duke Dan Powlus da duke is offline
Send a message via MSN to Dan Powlus da duke Send a message via Yahoo to Dan Powlus da duke
Hey, I get to chime in finally on something I know... I just replaced my heater core for about $38 at Autozone (had to order it), then when I put the new one in, I re-weatherstripped around it to seal it tighter, and I used aluminum tape on all the seams to keep the cold air out.
Seems to work better now.
Oh, yeah, and I vacuumed out the intake area.
'79 Scout Traveler 345 TQ 4bbl daily driver
new to me 60/40 split bench seat
factory rust option
GREAT LAKES BINDERS - from the Michigan area or around the Great Lakes? Stop into our little section of the BP in the Club Section
We need another hero like John Wayne
Old 12-06-2005, 02:53 PM
Got mine on ebay brand new for under $20.
I also redid all the seal strips between the box and core.
Also note that some are 90* fittings and some are straight.
The Go/Dan Industries number is 39 9418 (IH 2507) the
> oem number > is 488424-C1. It fits a 1974- 1977 International Scout &
> Scout II. The > measurements are 7 3/4 x 7 3/4 x 2. The inlet and
> outlet connections measure 5/8". .
100 , 110 , 1977 , 345 , aluminum , case , coolant , cracked , diesel , differential , door , number , part , radiator , rust , scout , scout ii , start , stuck , t-stat , thermostat , top , trail rig , truck , water
