Old 08-07-2005, 02:30 AM
NickHuddleston's Avatar
NickHuddleston NickHuddleston is offline
Default A Few Diesel Scout Questions from an amateure
I know I already posted these questions, but not in the diesel forum. Some of the replys to my forum consisted of "Post diesel questions on a diesel forum." So, here goes.
"Hi Everyone, I'm Nick, and I have a 1980 Scout II with a 6 cyl nissan turbo diesel in under the hood.
I have a coupla questions an' I was hopin' to get some answers.
1. Will any old scout II fuel gauge i get on ebay work with my diesel?
2. Will any old scout II power steering pump work with a diesel?
3. Speed liner or rhino liner? What's better? Any other options that are comparable? Perhaps something I can apply myself.
Any and all suggestions are most appreciated. Thank you. Hope I can return the favor some day."
~Nick~
Old 08-08-2005, 02:42 PM
xTrauMa xTrauMa is offline
Default Re: A Few Diesel Scout Questions from an amateure
How much does a Scout with A turbo diesel engine cost? I'm looking at gettin a scout and would love to have a diesel... not specifically for towing just cheaper gas prices and DIESEL! lol
Old 08-08-2005, 09:40 PM
My scout was $1200 plus $900 I had to put into it right off the bat. So I currently have around $2100 in mine. I got a good deal though. My scout runs great, just no power steering so that will be an additional hundred or so. I think that there is one on ebay right now going for $2500. I would guess diesel scouts go for between $2000 to $5000.
~~Nick~~
Old 08-09-2005, 07:07 AM
David Dixon's Avatar
David Dixon David Dixon is offline
~Nick~
1. IF your truck has a functioning stock sending unit or a chrysler type replacement sending unit in the tank, then any old scout II fuel gauge should be compatible. (Hard to say whether an ebay unit will actually work , I have had good luck myself. )
My truck has a replacement sending unit, chrysler type, and it works - sorta; At full the gauge reads 7/8 or 3/4. The gauge reads empty with 10 or more gallons left in the 33 gallon tank. Thats fine with me.
2. To the best of my knowlege, the scout II power steering pumps are the same, diesel or gas, HOWEVER, the manufacturer (Saginaw?) changed the hydraulic line fittings size and the holes they tap into at some point in the late '70s so early units are not compatible with late. A search in the tech talk section should reveal which model years match your truck. Also, save the mounting hardware from the old unit if you have it.
3. I used rhinoliner and got excellent results.
-David
David Dixon
'80 Scout Diesel - Somewhat modified , currently resting, awaiting a new windshield and new body panels (Like, most all of 'em.)
'78 Traveler, 345, auto, totally stock.
Old 08-16-2005, 10:52 PM
Mike Bolton's Avatar
Mike Bolton Mike Bolton is offline
Send a message via Yahoo to Mike Bolton
Before you spend your money for a Power Steering Pump for your Scout, make sure it's from an '80. The '80's used Metric fittings, unlike any other year of Scout.
One other thing I've noticed, is that the fuel guage on a gasser will have "Use Unleaded Fuel Only" on it, which is a moot point for us oil burners.
"Non-essential jargon"
Any other questions, ask away!
Mike
Keeper of the "Final Inscription"!
Old 08-24-2005, 06:34 PM
Hey Mike,
On the last forum I posted you said I could ask all the questions I wanted. My Question is again about power steering pumps. Like I said in the Forum I need a power steering pump that will fit a 1980 scout II diesel. I read in a different forum that some scouts could actually use a common type of Chevy power steering pump as long as I remount the pulley and reservoir from that old one on to the new one. I wanted to know if this is true, or if I have to buy only a 1980 Scout II power steering pump. If I can use a Chevy power steering pump, what kind should I get? How should I remount the pieces? Are there any other pieces to remount?
Thanks for your time,
Nick
Old 08-24-2005, 07:13 PM
pete wolla pete wolla is offline
I won't argue with the others here but I'm sure in my 80 ex diesel . I'm running the power steering pump the was stock in the 72 travelall the 392 came out of. i swapped in 84 or 85 so my memory is a little fuzzy.not sure what hoses i used. it worked fine though
Old 08-24-2005, 07:42 PM
Hey Mike,
.... I read in a different forum that some scouts could actually use a common type of Chevy power steering pump as long as I remount the pulley and reservoir from that old one on to the new one. I wanted to know if this is true, or if I have to buy only a 1980 Scout II power steering pump. If I can use a Chevy power steering pump, what kind should I get? How should I remount the pieces? Are there any other pieces to remount?
Nick
Chevy and IH both bought steering parts from the same supplier. An interchange manual such as hollanders would list which models used the same pump, but if you find one in a Chevy that looks identical and comes in an '81 or later model year then I would bet that it would work. I figure it is more trouble than it is worth to switch the reservoir on a used pump. The resevoirs are delicate and these pumps are everywhere. (I have never disassembled one.) Swaping the pulley is pretty easy IF you have a puller. Most auto repair shops should have one. If you don't have access to an appropriate puller then look for a pump with the same size pulley from a scout.
If you swapped the steering gear and hoses as well then everything would match up. The metric and the old standard threads may be close enough to mash together and not leak too.
-David
David Dixon
Old 08-24-2005, 08:11 PM
Ricky77's Avatar
Ricky77 Ricky77 is offline
~Nick~
First off let me welcome you to the oil burners world, I'm Ricky-you're Nick now we can talk like fellow diesel heads.
As far as the power steering pump goes let me tell you a story. I pulled a steering gear box off of a 1980 Scout II to replace the one I had on my 1977 Scout II (mine was tapped for a hydraulic assist). The only think I noticed was that the hose connections on the 1980 gear box were different than the ends of the hoses on the 1977 pump. Other than that it was a bolt on swap and it worked perfectly. I'd say the only problem you might have if you get a pump from an earlier year model would be the hose ends. I just took mine down to NAPA and had all new hoses built. I hope this helps.
Ricky 77
Diesel.....
100 , 1200 , 1977 , 1980 , 33 gallon , diesel , engine , gear , oil , parts , power , power steering , scout , scout ii , steering , switch , towing , travelall , truck , turbo , turbo diesel
