Old 06-14-2005, 11:22 PM
CareyWeber's Avatar
Diesel Herder / Moderator
Default HVLP Spray Gun
All,
I bought an HVLP spray gun the packaging says its from Gator Tools.
The packaging has this on it:
2 in 1 HVLP
Spray and Primer Gun with Regulator
Gravity type
600cc Cup
1.4 Nozzle
1/4" pipe inlet
Compresor required: 2 - 3 HP
Air consumption 1.6 - 4.0 CFM
GT7050
The Gun has H827W stamped in it and 45 psi max / 3 bar, so I think it might be a Hawk H827W HVLP spray gun.
Below are some pics of the packaging and the instructions.
Do you think I can spray with this gun with a compressor with just 4.0 CFM? In the instructions it says something about "air 4 consumption 12,3 CFM" (see the instruction pic).
Could I use this compressor and paint my scout with my HVLP gun.
http://www.porter-cable.com/index.asp?e=547&p=4794
Carey
Name:	HVLP Gun 2.jpg
ID:	11441   Click image for larger version
  • Carey
You're as cornfused as a cow on AstroTurf.
Old 06-15-2005, 12:11 AM
Bill USN-1's Avatar
Default Re: HVLP Spray Gun
If your compressor has a tank than consumption won't matter until you drain the tank down. than your out put will be limited by the compressor it's self.
You don't plan on holding the trigger down wide open continuously while painting do you?
If not then you should have no problem.
Now if you don't have a tank...get an old propane bottle and buy the conversion kit and make one!!! Cheap, easy air tank!!
Old 06-15-2005, 10:16 AM
William Griffin's Avatar
William Griffin William Griffin is offline
You would have to spray, then wait for the tank to fill. Compressor would run constantly and you would have a lot of water to deal with. My compressor does 18cfm @150psi with a 5hp 240 motor on a 120 gallon tank and while spraying it runs quite a bit.
Old 06-15-2005, 11:17 AM
JerryD's Avatar
JerryD JerryD is offline
Are you using an HVLP gun?
"Caveat lector..."
"You're looking at Scouts? You just sold a Scout!
Old 06-15-2005, 11:49 AM
CareyWeber's Avatar
Would work for just one paint job?????
Carey
  • Carey
Old 06-15-2005, 06:39 PM
Lava's Avatar
Lava Lava is offline
Carey
Carey-
That hvlp sprayer is gonna do the trick for you.
The whole deal is to put it all together and make the paint come out right.
LOTS of pressure never hurts, and control air flow @ the gun.
I run both a small 3 to 4 cfm and a 7 or so cfm and either works great.
I now have a water seperator on a 100 or so gallon tank and that works well.
I can easily run a sprayer like yours using only the 7 cfm and the 100 gal tank.
I used to run my sprayer with just the 3-4 cfm with its 4 or so gal tank and never had a prob. Of course I sprayed as Bill USN1 suggests, without holding the trigger continuously.
The main thing is to lay on that paint in a nice, even layer and that can be no easy chore if your paint isn't coming out of the sprayer right.
Take a piece of sheetrock or plywood and give yourself a lesson in the operation of that gun ya got.
Watch in particular the shape of the spray's discharge. Is it coming out in a fan or a little circle? You can control the amount of paint/air/and pattern with the little knobs on the gun. Figure it out b4 you go and paint the truck.
A conventional sprayer or even a cup gun works good too.
But the conventional really does take LOTS of power to run and the cup gun is pretty bulky to get in tight. That little sprayer of yours would be better if you could fit the paint inlet on the gun with a hose running to a cup on a stick much like an I.V. then you could turn the gun any which way and have a real ball!
1600Charlie 1963 model 80 stock everything o/d factory soft top-a few homespun mods
Old 06-16-2005, 12:51 PM
CareyWeber's Avatar
Originally Posted by Lava
Carey-
Lava,
Thanks
I really want to try to get some paint on my Scout so it looks better even if its a 10' paint job.
Carey
  • Carey
Old 06-16-2005, 12:59 PM
John Donnelly's Avatar
Administrator
(H)igh (V)olume (L)ow (P)ressure.
You can use a standard ol' 25 gallon compressor with one of those. Heck, Eastwood sells a version of an HVLP gun that has it's own compressor attached to a hose. The thing is about the size of a suitcase.
As long as you meet the HP and CFM requirements, an HVLP gun is easier than the old high pressure stuff ever was.
Binderin',
John
Old 06-16-2005, 01:04 PM
CareyWeber's Avatar
Binderin',
John
How low of a psi can a guy run a HVLP gun: 40psi, 30psi, 20psi, or 10psi?
Carey
  • Carey
Old 06-17-2005, 08:03 PM
My HVLP has a regulator at the gun which I set to 20psi. On my old regular gun I used a regulator at the tank set for 40. I sprayed the epoxy primer on my Scout today. With a 1.7 nozzle it took 2 fills of the gun to "get er done". It took about an hour and my big compressor was cutting on about every 5 minutes. I had about a 1/4 inch of water in the separator when I was done even though I had the A/C on in the shop to cut the humidity. Tomorrow morning I'm going for the finish coat. I'll post pictures when I'm done.
100 , bar , binderplanet , cable , case , conversion , fluid , orange , paint , panel , parts , pictures , power , rust , scout , top , truck , water
