Old 12-29-2005, 12:08 PM
crazyscoutproject crazyscoutproject is offline
Default Re: 5.3 Scout II
Originally Posted by BO185
the trucks are left hand drop on those years because of the body stule change.
my front axle is stock, so it needs a right hand drop transfer case to avoid an axle swap. Justscoutin said that the right hand drop comes from a K 5 or burban, the right hand drop will have the vss too right? My 5.3 and 4L60E are from an 02, why doesnt the stock transfer case for this engine have the vss i need?
Old 12-29-2005, 12:12 PM
peaceman's Avatar
peaceman peaceman is offline
Last year, me and some buddies took my 75 2WD Scout COMPLETELY apart and put in a 96 chevy 350 vortec. I got broke and let my membership here lapse, so I can't post any picts.
If anyone has any questions, you can email me: liddellliddell@yahoo.com
1975 Scout II, 2WD
soon to be Vortec 350-powered w/ auto
Old 12-29-2005, 04:34 PM
Binderman Binderman is offline
The next Gm engines the Gen IV will be in the trucks in 2007.
There is talk of a V6 Duramax also. How sweet would that be!!!
Looks like you are doing your swap right, not just hacking up a good scout to try and make a engine swap only to give up on the whole project after a little while.
Thanks for sharing!!!
"Disasterpiece"
1970 800A 4X4,HFI'd,304,B/W,27,44,3:73,28's.
"Ruedh" aka "Steve Austin" (needs more body work than he did!!)
FREE 1972 1110 4x4,V8,727,205,44 drum/60/3.54's,28's
www.northtexasbinders.com
Old 12-29-2005, 06:07 PM
BO185's Avatar
BO185 BO185 is offline
Yes the 88 to 91 should but be careful, it's will have a sensor and wires instead of a speedo hook-up! The stock 02 chevry transfer case is a left hand drop you can use it's pick-up ring and sender to swap in to the VSS on the NP241.
-73 Scout II- GM Vortec 6.0L 4L65E NP241
-73 1210 Travelette SV392, T-34, 60/14bff 4.56's 35's
-01 VW TDI Beetle- 50mpg or better
-55 Chevy 210 Delray 235/3sp
-56 Chevy Belair 4 door hardtop*next project* 5.3/4l60/3.08's
LSx swap info
Old 12-29-2005, 06:10 PM
BO185's Avatar
Yeah I had a vortec 350 swaped in mine before the 5.3 the first few engine pictures in this post #5 are the Vortec 350. Oh yeah those engines like to spin rod bearings! That's why I swaped, plus there are far more aftermarket parts now for the Gen III engines. I had to more the engine mounts back about 4'' for 5.3 to retain the A/C but other than that it's about the same size!
LSx swap info
Old 12-29-2005, 06:14 PM
BO185's Avatar
I looked for a D-max V-8 to swap in but there retarted expensive and I would go with the 6.0L Ford (IH) powerstroke anyway. I had not heard about the V-6 D-max sounds great but I doubt it will see the market the shape GM is in now. I bet it's kinda like the rumours of a F-150 V-6 diesel engine just all talk so far!
LSx swap info
Old 03-22-2006, 11:12 PM
BO185's Avatar
PINOUTS FOR GEN III VORTEC TRUCKS PCM
Blue connector
1 Ground BLK/WHT
2 Ignition LT GREEN (to crank position sensor)
3 Inj 3 PKN/BLK
4 Inj 2 LT GRN/BLK
5
6
7
8
9
10
11 KS Signal LT BLU
12 CKP DK BLU/WHT (to crank pos. sensor)
13 Req torque ORG/BLK (to electronic brake control module)
14 serial data ORG/BLK (to throttle actuator control module, fly by wire throttle)
15 serial data DK BLU/WHT (to throttle actuator control module, fly by wire throttle)
16
17 range b DK BLU (to transmission)
18 range c RED (to transmission)
19 ignition PNK (to fuse center)
20 B+ ORG/BLK (to fuse center, constant 20A fuse, ECMB fuse)
21 Ref low YEL (crank pos. sensor)
22
23 sens gnd PPL (EGR valve)
24
25 HO2S LO TAN
26 HO2S LO TAN
27
28 HO2S LO TAN/WHT
29 HO2S LO TAN/WHT
30 Coolant level LT GRN (on radiator)
31
32 PRND A BLK/WHT
33 BRK SW PPL (to black 14 pin connector then brake switch in car)
34 PRND P WHT
35
36 Inj 1 BLK/WHT
37 Inj 6 YEL/BLK
38 Lift Dive sig PNK/WHT (to suspension control module)
39
40 Ground BLK/WHT
41 Ground BLK (to transmission fluid temp sensor)
42
43 inj 7 RED/BLK
44 inj 4 LT BLU/BLK
45 +5V GRY (Fuel tank pressure sensor)
46 +5V GRY (TPS)
47 +5V GRY (MAP)
48 +5V GRY (EGR)
49
50
51 KS Signal
52
53 sens gnd (?)
54 sens gnd (?)
55 EGR input
56 Fuel Comp Sig (?)
57 B+ ORG (to fuse center, constant 20A fuse, ECMB fuse)
58 CLS 2 Data DK GRN (to OBD II diagnostic port pin 2)
59 CLS 2 Data YEL (to BCM fuel enable signal, serial data, VATS must be deleted in truck computers.)
60 sens gnd (?)
61 Ref low (?)
62
63 sens gnd (?)
64
65 HO2S HI
66 HO2S HI
67
68 HO2S HI
69 HO2S HI
70 Oil Level BRN (to oil switch in pan)
71
72 PRND B
73 CMP BRN/RED or BRN/WHT (to cam pos sensor)
74 ECT sig YEL (coolant temp signal, to sender in head)
75 Ignition PNK (to fuse center)
76 inj 5 BLK/WHT
77 inj 8 DK BLU/WHT
78
79 3-2 SS except 6.0L BRN or White
80 Sens rtn
RED connector
1 Ground BLK/WHT
2 TCC PWM BRN (to trans)
3
4
5 Delivered Torque TAN/BLK (to electronic brake control module)
6 PC SOL HI RED/BLK (to trans)
7 EGR Control RED
8 PC Sol Lo LT BLU/WHT (to trans)
9 Fuel Pump DK GRN/WHT (+12V power output for fuel pump relay to fuse center)
10 RPM out WHT (tach output 4cyl signal to black 14 pin connector)
11 Recirc Sw DK BLU (to 2 pin connector on passenger side of harness)
12
13 Cruise Eng LT BLU/BLK (to black 14 pin connector)
14
15 Gen L BRN
16 4WD Low GRY/BLK
17 AC REQ DK GRN/WHT
18
19
20 VSS Lo LT GRN/BLK (to VSS on side of trans)
21 VSS High PPL/WHT (to VSS on side of trans)
22
23
24 TP Sig DK BLU (to TPS sensor)
25 IAT SIG TAN (to mass air flow temp sensor)
26 Ign Ctrl PPL/WHT (coil )
27 Ign Ctrl RED or RED/WHT (coil )
28 Ign Ctrl LT BLU/WHT (coil )
29 Ign Ctrl DK GRN/WHT (coil )
30
31 MAF SIG YEL
32 MAP SIG LT GRN
33 Recirc Door DK GRN
34 Evap Can DK GRN/WHT (to solenoid on top of intake)
35
36
37
38
39 Ign Feed RED (cam pos sensor)
40 GND BLK/WHT
41 EGR GND WHT
42 TCC SOL TAN/BLK except 6.0L (to trans)
43 A/C CLU DK GRN/WHT
44
45 EVAP Vent WHT (pin C of blue 12 pin plug)
46 MIL Ctrl BRN/WHT (to black 14 pin connector chk engine light)
47 2-3 SS YEL/BLK
48 1-2 SS LT GRN
49 VSS Out YEL/BLK (pin E of blue 12 pin connector)
50 VSS Out DK GRN/WHT (to black 14 pin connector)
51 TFT Sens Sig YEL/BLK (to trans fluid temp)
52 Gen F GRY (2000 only)
53
54 Fuel Lev PPL (to pin K of blue 12 pin connector)
55 CYC SW in DK GRN (A/C system)
56
57 SENS GND BLK
58
59
60 REF Low BRN (to ign coils)
61 REF Low BRN/WHT (to ign coils)
62 PRND C GRY (to trans)
63 TRANS RNG A PNK (to trans)
64 Fuel SIG CTRL DK GRN (pin D of 12 pin blue conector, to fuel tank pressure sensor)
65
66 IGN CTRL PPL/WHT (coil )
67 IGN CTRL RED/WHT (coil )
68 IGN CTRL DK GRN (coil )
69 IGN CTRL LT BLU (coil )
70
71
72
73
74
75
76 IAC COIL HI LT GRN/WHT
77 IAC COIL LO LT GRN BLK
78 IAC COIL LO LT BLU/BLK
79 IAC COIL HI LT BLU/WHT
80 ORG/BLK (pin G of 12 pin blue connector)
Black 14 pin connector. Not labled a-n, just identify order by wire color/placement
A blu/blk pin 13 cruise engage Depends
B wht Power steering pump pressure sensor No
C pnk canister evap vent Depends
D grn pin 50 VSS out Depends
E ppl pin 33 TCC Break switch If using 4l60e/ 80e yes
F brn/wht MIL control Yes
G Grn pin 58 serial data Yes
H tan/wht oil pressure Depends
I wht pin 10 Tachometer Depends
J brn Power steering pump pressure sensor No
K yel VATS No unless using BCM
L brn 4wd low No
M grn A/C recirc. No
N grn/blk to fuse center Me no, but you ?????????
Blue 12 pin plug
A
B
C Gry pin 45 evap vent Depends
D grn pin 64 fuel signal control Depends
E yel/blk pin 49 VSS out Depends
F wht pin 45 EVAP vent Depends
G orng/blk Pin 80 Blue connector No idea what it does??????????????
H
J blk pin 53 Blue ????????????????????????
K ppl pin 54 Fuel level Depends
L
M
2 Pin black connector is fo 4WD low range Not used
Large Black plug for fuse box. Not labled just follow diagram to find wire
s
Pnk Injection 2&4 Yes
blk ground Yes
pnk coils odd Yes
pnk ignition 1 Yes
ppl Starter Depends
yel PRND switch No
pnk Injection 1&3 Yes
pnk injection 5&7 Yes
ppl/wht PRND No
grn PRND No
pnk PRND No
Orng Battery Yes
pnk Front o2 Yes
pnk Rear o2 Depends
dk grn/wht Fuel pump relay Yes
pnk evap purge Depends
pnk injectors 6&8 Yes
blk Ground Yes
pnk coils even Yes
blk/wht ground Yes
LT Blue A/C Depends
pnk MAF Yes
drk blu A/C recirc. No
Grn A/C compressor Depends
LT grn PRND No
grn/blk to blk connector No/Depends
pnk evap vent Depends
pnk Ignition 2 pin 75 Yes
LSx swap info
Old 03-22-2006, 11:19 PM
Scout21972's Avatar
Scout21972 Scout21972 is offline
Great info in the thread. That's a lot of work.
Old 03-24-2006, 01:11 PM
dsyes dsyes is offline
Great thread! I've a 97 Chevy with a 5.7 & NV4500 I've contemplated
swapping. The gas milage in my Chevy is 19-20mpg. What are you getting with the 5.3?
Dan
74 Scout II
345/T19/Edlebrock/Pertronix
D44 F & R. Trashlock in the back
4" lift. and a list of wants
Old 03-24-2006, 01:23 PM
BO185's Avatar
I had a vortec 5.7 in there before the 5.3 and go like 16mpg with the 35's 4.56's and overdrive. But I keep my foot in it! The pictures in post 5 is the vortec 5.7. Swap the 5.3 yet to get everything back together (fixing very rusty tub). I plan on putting in a 6.0L instead of the 5.3 BTW. I would think you could get 20MPG easy with a 5.3 provided it was in a stock scout with 30' 3.73 and overdrive.
LSx swap info
2wd , 4x4 , aluminum , broke , cam , case , cooler , custom , egr , electrical , engine , frame , front , ignition , oil , parts , pictures , power , project , radiator , scout , scout ii , transmission , truck , universal
