-73 Scout II- GM Vortec 6.0L 4L65E NP241 -73 1210 Travelette SV392, T-34, 60/14bff 4.56's 35's -01 VW TDI Beetle- 50mpg or better ![]() -55 Chevy 210 Delray 235/3sp -56 Chevy Belair 4 door hardtop*next project* 5.3/4l60/3.08's LSx swap info Last edited by BO185; 03-22-2006 at 11:17 PM. |
I have a 72 scout 2 and just bought a vortec 5.3 and 4L60E for it. The np 241 that your running is right hand drop and out of a 1990-1991 chevy? Did it bolt to your 4L60E or did it require a conversion? How much effort did your driveshaft work require? Any ideas on all of this or additional thoughts that you think i should know would be great.
Any more questions let me know. BTW those interested in all things GEN III related. I just got a 6.0L for X-mas! Plans include a stoker kit to make it a 408ci torque monster plus new cam as well. I plan to dyno the engine and looking for 400HP and 450TQ on all motor small block. I will dyno it in the truck after the swap as well to see the total lost of the drivetrain is.
thanks for the great info. I now have some new questions, you mentioned a JB conversions SYE and i dont know what that means or where to find out what it is. Im new to working on trucks and have undertaken a very ambitious project so bear with me if you would. Also, what is a ODB II port and where do i get one? thanks
sorry, another question, for the np 241 case, does it have to be out of a 90-91 truck, or could it be from other years?
ok....last one for now i promise, you said you built a custom fuel tank, is that a must? or can i just get an external pump and return line?
the right hand drop 241 comes specifically from a 88-91 k5 blazer or suburban.
In Progress. 72 Scout II, Cummins 4BTA, TH400, D300, d60 front, 14bolt rear, chvy 52" front springs, 63" rear springs. 38" sx's http://www.wheelindixie.com/forums/s...-CumminsBinder |
ODB II is the what late model vehicals use to read the trouble codes and interface with the computer. It's monted under the dash on most cars. Shoud come from the donor truck or buy the plug at a junk yard and wire to the correct computer pin #. Check out LS1tech.com for info on the GEN III chevrolet engines. Slip Yoke eliminator (SYE)
| 2wd , 4x4 , aluminum , broke , cam , case , cooler , custom , egr , electrical , engine , frame , front , ignition , oil , parts , pictures , power , project , radiator , scout , scout ii , transmission , truck , universal |
