#111
#112
#113
A friend is going to give me all the components to build a np205/203 doubler using a ford driver drop np205. Has anyone seen this large a setup under the scout. It would sure make for a super strong setup. I would be cutting the 27 spline output shaft of the 4l60e to fit in np203 and build a custom adapter that would retain the OEM VSS sensor. Any suggestions.
#114
As long as the VSS is in hte adapter before the transfer cases you will be fine.
#115
Shifted gears a little and got my hands on a 241 so I plan on making the doubler using the low gears out of it and adapting it to the NP205. I want to put the VSS on the 4l60e output shaft like AA does. I would assume the ECM would rather this cause the motor RPM and speed will be constant therefor shifting at right RPM not MPH. Also found some 2010 Camaro exhaust manifolds for $10 a set so I bought 2 sets. Thinking of running two passenger side manifolds so driver side will exit in the front under pan to tie into other pipe. Hopefully this will not interfere with the HP Dana 60 driver drop axle. Still indecisive on motor mounts. I would like to make some similar to M.O.R.E bomb proof style. Anyone know of any for ls into scout2.
#116
Just buy a universal SBC mount kit for X company and make adapter flats out of flat stock.
| 2wd , 4x4 , aluminum , broke , cam , case , cooler , custom , egr , electrical , engine , frame , front , ignition , oil , parts , pictures , power , project , radiator , scout , scout ii , transmission , truck , universal |
