nicky |
Your lacking a good ground to one or more of your lights in those circuits. Best way is to ground everything real good and your promlem(s).
Shell or housing to lamps Battery negative to frame and body Engine to frame and body. Dick S. Moore
Dick S.Moore |
Work the hazard switch in and out. This would keep the signals from working, and if you have the hazards on and hit the brake, the signal lights light up. I would also check to see if your hazard flasher is working.
Dave Robson Former owner of a 1980 Scout II Diesel Midas |
Don`t ask!!
Your lacking a good ground to one or more of your lights in those circuits. Best way is to ground everything real good and your problem(s) will go away. Shell or housing for lamps, to body or frame. Battery negative, to frame and body. Engine, to frame and body. Dick S. Moore
Dick S.Moore |
turn signal switch probs.
| body , brake , brakes , frame , front , ground , lights , switch , turn signal |
| Fullsize D44F brake shoes? | Ronnie | General IH Tech | 9 | 04-02-2004 12:08 AM |
| Electrical Brake Switch | ttgchicago | General IH Tech | 3 | 02-24-2004 07:00 PM |
