Old 04-25-2005, 06:47 PM
Munchies Munchies is offline
Send a message via AIM to Munchies
Default Front Wheel Bearings?
I am having trouble locating part #'s for my front wheel bearings. I beleive they are the cause of my wander and they need replacing. Left and right, inner and outer.
Old 04-25-2005, 08:11 PM
Jim's Avatar
Jim Jim is offline
Default Re: Front Wheel Bearings?
This page might help:
http://www.off-road.com/ih/jweed/part_num.htm
Old 04-25-2005, 08:46 PM
George Womack's Avatar
Scout II front wheel bearings:
Inner Timken SET 47 or Cone LM102949 Cup LM102910
Outer Timken SET 45 or Cone LM501349 Cup LM501310
Old 04-25-2005, 08:56 PM
Is there a way to know if I have cone or cup before pulling it apart. I want to pick the parts up, and install them. With little down time.
Old 04-25-2005, 09:04 PM
Nevermind I get it DOH!
Old 04-25-2005, 09:07 PM
Each bearing consists of two parts, a cone and a cup, AKA bearing and race. Both parts should be replaced as a set. The Timken SET numbers provide both parts. I also listed the separate cone & cup numbers because some suppliers may not have them listed under the SET numbers.
Old 04-25-2005, 09:30 PM
So is timken the preferred bearing? I am looking at the screen with $92.12 in BCA bearings, and remembered hearing timken is the best, is it worth shopping around? Where can I find timken bearings.
Old 04-26-2005, 05:08 AM
hounddog's Avatar
hounddog hounddog is offline
auto zone has the timken bearings you are lookin for i just replaced mine last week.
Old 04-26-2005, 08:02 AM
grannygear grannygear is offline
Good idea to replace them as quickly as possible. I had a front wheel bearing go out on a CJ7 while on the freeway. Took the CJ across two lanes before I could even say J**P. Scary
Expensive, too. New spindle, hub, etc.
1967 800...a work in progress. 3 Years later and finally out of the garage!http://www.c4x4.com/tech/projects/oldscout/mainTOS.html
bearings , front , part , parts , pulling , scout , scout ii
