Old 04-05-2005, 04:58 PM
ttgchicago's Avatar
ttgchicago ttgchicago is offline
Default Summer Gas / warmer weather
Ive noticed recently my Scout has started idling a bit higher. Is this possibly from "summer gas"? Would the newer mixtures be out yet?
I assume Ill just turn down the idle screws, but wanted to verify that there wasnt some other step I should take (play with the timing?) now that its getting warmer out.
Also, aside from thicker oil, what other simple changes do people make as we transition from winter to summer?
TIA
1980 Scout II, 160k Mi
304, T-407 (727) auto, D20, 3.31, Holley 2245
30x9.5 Bridgestone A/T's
Old 04-05-2005, 08:36 PM
Dan Schepp's Avatar
Dan Schepp Dan Schepp is offline
Default Re: Summer Gas / warmer weather
Could be a choke adjustment.Summer gas is already starting to flow in the pipeline according to my gas hauling buddies.Nothing like another summer with crappy gas.. Dan
work hard,play hard, live long!
There is a fine line between" hobby" and "mental illness".
'71 travelette
'71 travelall
'72 travelall
'73 pick up
'79 scout
'80 scout
Old 04-05-2005, 11:16 PM
Dave Nuenke's Avatar
Dave Nuenke Dave Nuenke is offline
Send a message via AIM to Dave Nuenke Send a message via Yahoo to Dave Nuenke
Thank goodness South Dakota doesn't do the "summer gas" thing, the benefits of living in the middle of nowhere........
Dave
Old 04-06-2005, 12:02 AM
Dan Phariss's Avatar
Dan Phariss Dan Phariss is offline
TIA
I run the same oil winter and summer.
Mostly Amsoil synthetic. Have a couple on Shell 15w40.
Dan
Dan Phariss
66 1200A 4x4
74 200 4x4
75 200 4x4
"The meek shall inherit the earth, generally in small plots about 3X6X6." Robert Heinlein
Old 04-06-2005, 10:00 AM
ttgchicago's Avatar
Dan
I run the Mobile1 15-50 as much as possible, but end up throwing a few qts of 5-30 in in the coldest months to help with startup.
Luckily, the thinner stuff ends up all over my garage floor, so it doesnt stay in there long enough to force an early oil change!
Old 04-06-2005, 10:15 AM
Brian Dalton's Avatar
Brian Dalton Brian Dalton is offline
Your Low Post Leader Since 1999
TIA
Top removal
'79 Scout II SOA, RS, Propane, Bobbed...all that stuff
WARNING: Ensure front axle is engaged prior to yanking the gates off Hell
On the 'con!!
efi , idle , oil , scout , screws , timing
