Old 03-29-2005, 06:50 AM
bbellster bbellster is offline
Default hydro-boost seals found
I don't want to step on Vanco's toes, but after an extensive search, I finally found a source for the input and output shaft seals for my hydro-boost. It came off of a late 70's GMC 1-ton, but as far as I can tell all the GM units look about the same. Anyway the place is called Elder Rubber 1-800-231-2099. They are located in Texas somewhere. The only bad thing is that you have to buy a min. of 25. Its not as bad as it sounds though, they are only $0.40 each.
You should be able to give them the old Bendix part number on the seal.
Bendix #_______________ Elder #
129540 _______________ 9-140
129484 _______________ 5-19
I don't know about everyone else, but this sure beats paying $180-$200 for a rebuild, just because the seal leaks.
Brett
Old 03-29-2005, 09:44 AM
CareyWeber's Avatar
Diesel Herder / Moderator
Default Re: hydro-boost seals found
bbellster,
That is great info.
Carey
  • Carey
You're as cornfused as a cow on AstroTurf.
800 , number , part , rebuild
