Old 12-22-2004, 10:07 AM
Buchanere's Avatar
Buchanere Buchanere is offline
Default Small Alternator pulley
I have just about finished my wiring upgrade for my 135 amp alternator, on my 1978 Scout 11 345ci. The last piece of the puzzle is a smaller alternator pulley. There are part #s in the faq, but they are old, and discontinued. Has anyone recently done the same upgrade with the smaller pulley. If so, what did you use, and where did you get it from. Has anyone out there got one to sell me..
Old 12-22-2004, 11:55 AM
Default Re: Small Alternator pulley
what size do you need?i've got many of them...id of shaft hole an od of pully?jeff
Old 12-22-2004, 12:20 PM
Buchanere's Avatar
Hi Jeff. Here is what I would like, but have an awfull job finding. A Delco Double Pulley, with a lester # of 7122, 7127, 7145, a bore diameter of 0.670", and outside diameter of 2.81". That would really make my Xmas if you have one..
Old 12-22-2004, 12:24 PM
RD Durham's Avatar
RD Durham RD Durham is offline
I've posted this before, but here it is again.
Alternator Pulleys
Here's some material on double pulleys that can be used on the Delco alternators (10si, 12si, 15si and 17si) that can be used or found on IH vehicles. The "Lester Number" is kind of a universal parts number for automotive electronic components. Most auto parts stores, especially specialty houses, can cross reference a Lester No. to their propriety parts number. So long as the bore diameter is 0.670" you can use the pulley. The multiple Lester Nos. below just indicate that there is more than one application for that pulley size. I've been using the smaller Ford double belt pulley, a little easier to find in junkyards as it was used on a lot of Ford trucks to run the air pump off of the alternator.
Delco double pulley used on International Harvester vehicles
Lester No.: 1852856 ??
Bore Diameter: 0.670"
Outside Diameter: 4.37"
Delco double pulley
Lester Nos.: 7122, 7122, 7127, & 7145
Outside Diameter: 2.81"
Ford double pulley
Lester Nos.: 7701, 7704, 7705, & 7716
Outside Diameter: 3.31"
Ford double pulley
Lester Nos.: 7084, 7088, 7716, 7723, & 7738
Outside diameter: 2.56"
Ford double pulley
Lester No.: 7758
Bore diameter: 0.670"
Outside diameter: 2.95"
R. Dale Durham
Colorado Springs, CO
1980 Terra
392IC V8
T19 Wide Ratio
Dana 300 T-Case
Four wheel disc brakes
SOA w/2" body lift
Warn 8274 winch
On board air and welder
Optional rust, custom dents & multi-color body parts
Old 12-22-2004, 01:57 PM
buch,i'll take a look an see what i got!jeff
Old 12-22-2004, 06:02 PM
WilliamEHardy WilliamEHardy is offline
Send a message via MSN to WilliamEHardy Send a message via Yahoo to WilliamEHardy
If you don't find anything of the correct diameter/belt size, there's always some of the rebuilders - used to be Ace Electric in Phoenix that was a supplier to rebuilders, but the parent company went Chapter 11 so I'm not sure of the status of the locals - other than that there's WAI (another supplier) but they're in L.A., so hopefully something more local will pan out. 670 bore pulleys are very common, so it shouldn't be too much of a hassle!!
Bill
"Life is not just a journey to the grave with the intention of arriving safely in a pretty & well-preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming:WOW! WHAT A RIDE!!!"
Old 12-23-2004, 04:48 AM
hounddog's Avatar
hounddog hounddog is offline
you might look into a GM model. i got a gm 1 wire alternator (140 amp) that came with a smaller pulley that the stock one, but it was only a single pulley set up. it was made by powermaster.
Old 12-23-2004, 11:10 AM
ScoutmanSV's Avatar
ScoutmanSV ScoutmanSV is offline
Don't forget that if you run a dbl pulley alt > you need the correct crank & water pump pulleys too. Gets kinda crowded if you run PS, smog pump & AC too.
.02,
Kevin
SII x 6
Proud Member of the 500,000 Mile IHSV 304 Club!
IHOnly IHOnly North "Race Proven Technology"
alternator , electronic , faq , number , part , parts , scout , universal , water , wiring
