AZIHR 2015
Old 08-09-2004, 02:00 PM
NavyFO NavyFO is offline
Default '67 Scout 800 Brake work
I'm working on replacing all my brake shoes on my Scout ('67 Scout 800, four wheel drums). The Binder FAQ here has a "cookbook" method for replacing the brake pads for the front disc brakes, but is there any "cookbook" type document somewhere that explains how to change the brake shoes on drums? Any help would be great. Thanks!
Old 08-09-2004, 02:43 PM
George Womack's Avatar
Default Re: '67 Scout 800 Brake work
The IH service manual for Scout 80/800, CTS-2302.
Old 08-09-2004, 05:42 PM
janhighboy's Avatar
janhighboy janhighboy is offline
Just do one side at a time so you have the other for reference if things go wrong.
Start with the three springs, two on top one at bottom. Remove the self adjuster cable and hardware if so equipped. Remove adjusting star assembly if it hasn't already fallen out when bottom spring removed. Remove shoes by pushing and twisting the cap so it comes off the pin and spring in the center of shoe. Undo parking brake assembly if equipped.
Assembly is reverse of removal.
You can do it with pliers, vicegrips and a screwdriver, but the drum brake service kit that is sold at checker or autozone makes it a bit easier and should cost less than 20 bones.
If you have a digi cam, take pics along the way so you can remember how everything goes, step by step. ---Jan
The wheel is an extension of the foot. The wheel is an extension of the foot. The wheel is an extension of the foot.
67 T-all 392 non-IC/T98WR/NP202/D44's/4.10F/3.73R
Old 08-10-2004, 04:03 PM
Thanks janhighboy, just what I needed.
800 , binder , brake , brakes , cable , cam , cap , disc , faq , front , scout , scout 80 , scout 800 , start , top
