I seem to have no luck with removing the knuckle so far, but I have not gotten the special tool for it...if it is even needed. Seemed like a big hammer would do it, but maybe not. Wondering why I cannot leave the stuff attached as long as I can make the measurements, grind and pound it around to where I need it, etc. Would the heat from welding affect the ball joint? Does not seem it would, it is pretty far away from the weld joint. Before I go out of my way to remove them...any thoughts besides, "just do it like everyone else, you slacker!"
1967 800...a work in progress. 3 Years later and finally out of the garage!http://www.c4x4.com/tech/projects/oldscout/mainTOS.html |
You have to grind into the knuckle a bit to get past the penetration of the weld. Grind a little and whack the hell out of it. I used a five pound sledge. Eventually you will see a line form where you have gotten past the weld.I wouldn't know about the ball joint as my axles have not been rewelded yet because I've decided to go with dana 60's in the middle of the project. I think that most folks go ahead and replace the ball joints while they are easy to get at but, you can always weld first and see what happens. Good luck with the c's, I know it's a pain in the arse.
1972 Scout II 345/727 D60's F&R Welded Rear/Locked Front 38.5 SX's Rear Discs Hysteer with Hydraulic Assist Fuel Injected 203/300 doubler |
I forgot to mention if you have a portaban use it.
A clarification on the parts terminology: the (steering) knuckle is the outboard large moving part that the spindle/brake parts/tie rod attaches to and is attached to the axle housing via the ball joints.
The fixed part that is welded on the end of the axle tubes is usually referred to as the *end yoke*. That said, I wouldn't know how one could accurately re-position the end yokes (cut-and-turn) without removing ALL of the other outboard parts. The flat milled surfaces on the top aspect of the end yokes provide a reference point for caster angle. It will also enable you to install nice new ball joints on the freshly modified axle. |
portaban....... are you talking cut through the weld , knock the yokes off then gring the old weld off to clean things up?
sounds like a good idea. I will have to bring one home from work and try it out next weekend. Did you knock the yokes off to do the clean up or did the blade take out enough material that the grinding was mimamal?
Actually, the correct angle measurement is possible, i think. Look at it this way. Even if there was no room to get to flat sections of C (but there is, actually) without the steering knuckles removed, all you need is a reference point to measure before the turn, and then after to bring it back to the measurement, yes? So, what is the trick to getting the knuckles off? Hmm...I will search a bit on that subject.
I'm pretty sure the reason to remove the knuckles is to have room to get a good swing at it. These won't be firm taps, but smack it like you hate it impacts. Not only will you be breaking a certain amount of weld, but you'll be turning a yoke that is machined to fit very tightly onto the tube. Pretend you're the governator and whack away.
I never did ball joints in the scout axle, in my chevy axle there is a loosener in the upper ball joint taper, takes a funky pronged socket. Besides that, it takes lots of pressure, top and bottom. Pickle forks might work for you. Tapping the side of the taper with a hammer can help it release. |
| axle , axles , ball joint , brake , brakes , caster , gage , oil , parts , project , scout , steering , tach , tie rod , top |
