Old 07-26-2004, 08:12 AM
Eric Underriner Eric Underriner is offline
Default Help Pic of D300 Front Output Needed
I need to compare a scout d300 front output shaft to a 32 spline upgrade shaft for a jeep d300 made by JB Conversions. Does anyone have a picture?
Old 07-26-2004, 04:57 PM
troutbum troutbum is offline
Default Re: Help Pic of D300 Front Output Needed
here is the JB shaft (clean) and a stock D300 shaft (dirty)
The JB shaft is a PITA you have to mill the bearing cap.
IH black sheep
Old 07-29-2004, 09:48 AM
Mark Ashford's Avatar
Moderator.. or something
Unless you got a hole in that piece of cardboard that looks allot like a REAR output-shaft... not the front. The front has a "tail" on it for the rear bearing.
What "bearing cap" did you have to grind???
Old 07-29-2004, 01:32 PM
it is just how the foto is cropped
here is the rear shaft
for the front 32 spline upgrade (JB) I had to mill the front bearing cap, it is the aluminum cap into which the shifters and shiftrail seals are integrated. Royal PITA
IH black sheep
Old 12-05-2006, 12:37 PM
Troutbum-
Could you post up the details on exactly what you did to install the front output? A buddy with a VERY complete machine shop has "volunteered" to rebuild my d300 with 4 to 1 and a 32 spline front output (I already have a AA 32 spline on the rear). Thanks in advance.
Eric
aluminum , cap , front , machine shop , rebuild , scout
