Old 08-30-2010, 06:10 AM
Default Re: lug bolt pattern for 1974 4X4,8 lug,3/4ton IH PU????
Considering that disc brakes have been stock on 3/4 and 1 ton trucks for almost 40 years I don't think it will be a problem finding stock or aftermarket rims that will clear the brakes. Unless you find and want to use rims that are 40 or 50 years old
Old 08-31-2010, 12:43 AM
DavidWTravelallfan's Avatar
DavidWTravelallfan DavidWTravelallfan is offline
Send a message via AIM to DavidWTravelallfan Send a message via Yahoo to DavidWTravelallfan
They will be new ones from 4 wheel parts, chrome steel wagon wheel type. same like i have now but not as wide.
72 Travelall 1200 4x4, 392. Im the "Picasso" of rattle can paint jobs.
Old 09-02-2010, 11:42 PM
Kitchen Kitchen is offline
Can't say yes for sure because I put 17" on mine but most everyone I asked said the same thing. 16 x 8 6.5 so they should work just fine. The rims I picked only came in 17+ or I would have gone with 16 because the tires are cheaper and you can fit more tire with out a lift.
2wd , 4x4 , aftermarket , bearings , brake , brakes , door , drum , front , front end , hub , ifs , parts , seats , size , studs , tire , tires , travelall , travelette , truck , wheel , wheels
SD22 and SD33 same bolt pattern? wwwabbit Diesel Tech 3 10-21-2010 07:03 PM
Changing lug pattern Goober Triple Diamond Trucks 10 04-12-2005 12:12 PM
Which vehicles had the 6 x 7.75 lug pattern? Rick General IH Tech 1 05-03-2004 10:41 AM
RA-20 bolt pattern Four Paws General IH Tech 0 02-15-2004 09:46 PM
Scout 80 Lug Bolt Pattern - Whose'll Fit?? GreatScout General IH Tech 13 01-26-2004 04:28 PM
