Old 04-17-2004, 11:20 AM
mdmcs1's Avatar
mdmcs1 mdmcs1 is offline
Send a message via Yahoo to mdmcs1
Default duraspark conversion help
hey all!!
i gonna use a spare gold box dizzy that i converted to duraspark guts on my in-laws grain truck.
question is this:
i want to use the gm hei module to fire the coil. if anyone has done this, what pins did you connect the pickup wires to? specifically which pin did you hook the orange wire to and what pin did you hook the purple wire to.
from what i have read here before - if you swap these around the wrong direction it wont work quite right.
as it sits now it is working great and making good spark no matter which way i have the pickup wires hooked up. but i wanna make sure i have it right before i hard-wire it in place.
thanks guys!!
michael
Michael Meyer
A.S.E. Certified Master Automobile Technician
Owner: Meyer Technology
Car/Truck/and Small Engine Repair
Computer and Printer Repair
77 IH Scout Traveler Midas
pictures at:
Old 04-17-2004, 01:50 PM
Default Re: duraspark conversion help
Purple to P and orange to C or N depending on how it is labeled.
All the wiring for the conversion is on the www.justinternationals.org site.
It's part of the FI conversion using the DS conversion and the GM ign module.
Old 04-18-2004, 01:19 AM
mdmcs1's Avatar
i looked around at that site for hours, i cannot seem to find the wiring on the site at all.... help me out man!!
Michael Meyer
pictures at:
Old 04-18-2004, 08:45 AM
wiring
Here is the EFI wiring.
I think I have one from a guy that used it and piggy backed his accel ign on to it if you want to see that one.
Old 04-18-2004, 09:06 AM
mdmcs1's Avatar
thanks a bunch bill, that picture does wonders! i am using the old non-ecm controled hei module, i gotta go check out pin letters on what i have and see if it still matches the newer ones
Michael Meyer
pictures at:
Old 04-18-2004, 10:43 AM
Mechanos Mechanos is offline
It will run either way.... however, if you have the wires backwards, it will retard the timing instead of advancing it. An easy way to check is to start up the engines and shine a timing light on the timing mark. Have a buddy hit the gas and if the timing retards, shut it off and switch the wires. If the timing advances, you're good to go.
aka TORC
'80 Scout II
Old 04-18-2004, 12:58 PM
I don't think that applies here.
He is only using the EST to trigger the ignition.
Since he is not running an ECM there is no timing signal from the ecm.
But if he changes his mind later, at least he has the wiring diagram.
binder , coil , conversion , ecm , efi , gold box , ignition , orange , part , pickup , start , switch , timing , truck , wiring
Another Scout Project OregonGirlScout IH Scouts & Trucks of Oregon 247 07-22-2007 01:11 PM
Hydra-boost conversion EJC36S General IH Tech 3 02-24-2004 07:47 PM
Gold Box connected to Duraspark? Scoutzor General IH Tech 2 01-24-2004 08:17 AM
Dana300 Twin Stick Conversion - Am I Confused? mmuthart General IH Tech 18 12-17-2003 07:20 AM
Twin-stick conversion Ron Brown General IH Tech 2 12-03-2002 08:28 PM
