Old 07-11-2012, 03:13 PM
fredsterra's Avatar
Default Re: Oil Breather
If you run too small dia of hose to the air cleaner from the valve cover. The air will travel too fast and pull oil into the cleaner.
I used my spark arrestor that was stopped up. Poked all the junk out and used steel wool on the inside. Then used 2 Ford PVC elbows and about 12" on low pressure oil line. To the bottom of my Summit 14x2 air cleaner.
Sorry I don't have the Dorman numbers handy for the elbows. But the fit the OD of the spark arrestor and the air cleaner. And the OD of the hose will push into the ID of the elbows. I used a dab of Right Stuff as a glue and seal just to be sure. Along with small hose clamps on the arrestor and air cleaner tube. Just to make sure it was sealed tight.
But works well and almost looks like an OE hose.
Mark Fredrick
Madisonville Ky
air cleaner , air filter , air filter housing , binderplanet , build , build up , carb , case , door , engine , filter , front , gas , hose , info , oil , power , pulling , scout , screws , start , tube , valve , worth
Low oil preasure. NVScouter General IH Tech 9 11-05-2011 06:37 PM
For "compulsive oil changers" Dan Phariss General IH Tech 40 03-22-2004 03:10 PM
Reason for oil leak? Repost from other board... Dennis Bernth General IH Tech 22 02-13-2004 07:26 PM
Oil leaks Larry Wagner Diesel Tech 2 04-30-2002 10:28 PM
